Q-Rings on P2 - Chain drops between rings on Downshift?
Last post 06-18-2012 12:13 PM by Stephen. 2 replies.
  • 06-18-2012 9:10 AM
     I have Q-rings (50/34) on an otherwise stock 2010 Cervelo P2 with Shimano Ultegra 6700 parts. When downshifting from the big to small ring, the chain sometimes slips between the rings and spins freely. This happen more often when in the smaller cogs. I have to switch to the middle cogs and shift up and down again to get the chain on the small ring. Is there anything I can adjust to remedy this issue?
  • 06-18-2012 9:24 AM In reply to
    Re: Q-Rings on P2 - Chain drops between rings on Downshift?
    Check the FD alignment and cable tension.
    Are the chain or chain rings maybe worn out?
  • 06-18-2012 12:13 PM In reply to
    Check the inner ring isnt on back to front. Easy to do and it moves it a mm or so inboard which now leaves a bigger gap between the rings than normal. Can still cycle and change gear, but will get the accasional drop
    Its very easy done (Guess how I know!)
    Cervelo S3 2011, 6.6kg with lots of bling
