Bicycle computer reviews:
Shimano 6502: Very nice computer for Shimano drive train owners, simple and is feature rich. One of my all time favorites
Pros:
Nice integration with Shimano levers and buttons
Virtual Cadence eliminates the weight of cadence sensor and keeps bike clean
Nice display with the added bonus of showing what gear you are in.
Can be set up to not cause extra aero drag on bike.
Wireless is clean and easy to set up.
Reliable on every ride
Cost is reasonable for what you get
Cons: Setup of the head unit to the levers can be tedious but worth it.
Polar 600CS: Very feature rich but setup is a real pain especially if you have the wattage package. I do not recommend getting the WIND power package it is a real pain in the *** to set up and keep set up. Sensors have a hard time starting and stopping reliably on every ride.
Pros:
Good info such as calories, grade, zones and timers as well as bike info.
Bike functions are easy to set up.
Software once mastered are very useful for analysis
Easy to sync with PC for uploading data.
Good mounting functions.
Cons:
All the sensors make your bike look cluttered. I dont like their cadence sensor.
WIND power sensors are to involving and makes the bike look loaded. Sensors do not pick up info reliabily.
Cost is ridiculous for what you get.
Really don't recommend this computer with the wattage functions but for the cycling functions its ok although you can get the CS400 or CS200 for cheaper for that.
Powertap 2.4 SL: Great wattage and computer combo, Easy to set up and clean on the bike.
Pros:
Great product and easy to use with good data collection and reliable.
Good mounting designs
Still one of the best options when you want wattage data.
Wattage and all functions are useful.
Newer models of the 2.4 will have ANT+ chip to work with Garmin 705
Highly recommend this option if SRM is to expensive
Cons:
Pricey when you have to build your own favorite wheels for trainning and racing.
Limited use due to having to slave to one wheel
Software is ok not great
Cateye Strada: Bought this due to its incredibily small size 60 gms total.
Pros:
Compact and lightweight
Sensors are wireless and easy to setup
Cheap and has basic cycling functions
I accidently washed the head unit and it came out fine so its water resistant
Cons:
Mounting bracket for stem breaks easily as confirmed by several other riders
Throw away type computer.
Limited info and data
Garmin 705 Edge with City Navigator package: Absolutely one of the most feature packed computers I have ever used. Its my new all time favorite.
Pros:
Easy to setup and rear mounted sensor detects both cadence and speed in one sensor so bike is clean and more aero than front mounted sensors. Sensors are reliable on every ride.
Well designed mounting brackets that are simple and sturdy
Speed is calculated via satellite as well as time so no calibration needed.
UP to 8 pieces of data can be setup on any screen and up to 16 different data fields can be shown over two screens. Buttons are very easy to operate and intuitive. Its nice to be able to setup what data you want and where you want it to show up. Lap counters are very nice and easy to access.
Uploading via USB is the easiest of all computers and reliable. Online software from
www.motionbased.com is awesome it keeps track of your ride and draws it on Google Earth and gives you data as well as weather report for the time of the ride. I was surprised at how the data revealed certain things about my riding that I had no clue about such as pie charts for climbing vs speed vs gradient vs Heartrate and how long you spent in what zones. Info is broken down in new ways that other software have not done before.
Virtual partner helps you beat yourself on every ride from the last stored ride similar to what is avaliable on the computrainer.
Color screen with good resolution. Display is easy to read and has back lighting for night time.
Lithium ion battery is rated for 15 hours but I got 13 hours with heavy use and turning on the back lighting to high for testing.
Incorporates the new ANT+ chip which is like standardizing bluetooth so SRM And Powertap can now be used with this unit.
Navigation unit can be used in cars, walking and riding.
Live gradient display using atmospheric pressure is very accurate and has helped me decide what gears to stay in during long climbs. Much better than Polar unit.
Highly recommend this computer its now my all time favorite and helps me improve my riding like the computrainer does. Make sure to buy the delux package so you get the City Navigator software on SD card.
Cons:
Price is very high about 550.00 on Ebay but sure beats the polar 600cs for features at less cost.
Head unit is largest of all computers at about 60gms but the data and graphics compensates for it.
SRM power meter and computer: Best power meter period. Durable and reliable. Buy this if you have money to burn or you want to eventually go pro.
Pros:
Wireless version is easy to install and effective with good fields of data.
Few parts to install
Accurate and reliable
Newer model works with ANT+ chip so Garmin will work with it
Easy to use and good software
Can use any wheel combo unlike power tap
Great to use as a guide for fitting and testing new wheels, tires and tubes on efficiency
Cons:
Heavy if you add the power meter and cranks with computer head
Cost is crazy. Not worth it for the amateur rider that will never use it to its full potential. This is definitely a pro level device much like Light weight wheels, Mavic CCU and Lew wheels are for pro category equipment. If your paycheck depends on you winning on a bike then this is worth it. Power tap can do much of what this can for half the price.
Head unit is rather large, I prefer using the Garmin head unit instead
If you don't need navigation then get the Garmin 605 since its the only unit other than the 705 to get the 15 hour rechargeable lithium ion batteries.
