optimal rear wheel placement for P2C
Last post 08-07-2008 11:59 AM by mikeP2C08. 1 replies.
Page 1 of 1 (2 items)
  • 08-06-2008 10:25 PM
    Maybe it posted here somewhere and i couldnt find it. anyways... How close or far is optimal placement for the rear wheel to be from the frame cutout? a few mm? a cm? thanks for the thoughts. I currently run about 4mm or so, but not sure if this is best. thanks
  • 08-07-2008 11:59 AM In reply to
    Re: optimal rear wheel placement for P2C
    I think 4mmm is probably good; i've seen a range of 3-5 posted somewhere, if not here.  It'll depend on how much debris you think you're likely to pick up on a given course.  I put a strip of chainstay protector along the inside of the cutout to protect the paint.  Every once in awhile it'll make this quick little screech/skid noise when something gets pinched through between the tire and protective strip, then I know i'm close enough.
