3T vs. P3C
Last post 08-07-2008 11:49 AM by mikeP2C08. 2 replies.
  • 08-07-2008 3:46 AM
    3T vs. P3C
    I just buy a Cervelo P3C with the new 3T fork. I used it once on the road and few times on the wind trainer without problem. But yesterday I noticed that the fork is not stable enough in the head tube when I used the front brake. The fork is playing in the frame. I tried to fix it but couldn't succeed. Any help or advice highly appreciated.
  • 08-07-2008 4:10 AM In reply to
    Re: 3T vs. P3C
    Your headset is loose.
    Loosen the bolts in the stem where it clamps onto the steerer. Then tighten the bolt in the top cap of the fork until the play is gone, this is known as pre-loading the headset. ( The best way to do this is to hold the front brake and try and move the front of the bike back and forth. ) When you are happy that it is just tight enough so that there is no more movement tighten up the stem bolts ( to the recommended torque ) and you will have not more problems.
    If you're still a bit unsure, take it to your bike shop and they will sort you out.
    More info here:
    See section: Headset Adjustment - Threadless Type
    http://www.parktool.com/repair/readhowto.asp?id=65
    Allen.
  • 08-07-2008 11:49 AM In reply to
    Re: 3T vs. P3C
    One possible problem I've seen before may be the height of stem+spacers is too close to the top of the steerer tube so it contacts the compression cap... might need a thin spacer above the stem (or replace current w/ one slightly thicker) so there's a slight gap between the top of the steerer and the compression cap to give it room to squeeze downward.
