How does the 3T Funda Pro compare to the True Temper Wolf SL Fork? Is it just as good, if not better?
According to Gerard (Vrooman) it's an upgrade: http://forums.cervelo.com/forums/t/1928.aspx?PageIndex=7 (fourth post).
It's better. I've just been using mine for a week, it's stiffer.
The steerer is much stronger, the tubing is thicker.
got my replacement 3t fork last nite 42 grams heavier, nice finish, no stiffer than wolf sl and yes steerer is thicker, only says funda on fork, not pro or team, and the tabs on fork have to be the biggest i've seen
How do you tell that the fork is stiffer than the last?
I just got back from my first ride on the new 3T Funda. Honestly, I could not tell you the difference between it and the Wolf SL other than appearance. At least in terms of handling and vibration...they seem almost identical to me. On the other hand, I do think that the distance between the Crown Race and the Brake hole is a little larger on the 3T. When I went to put the brake back in, the housing/cable was too short. I had to remove a spacer so I could get out and ride.
Of course Cervelo will say its an upgrade! It wouldn't be wise to say that its just equal or worse than the SL
