Which Cervelo is the best climbing bike?
Last post 12-24-2008 8:31 AM by webmaster. 8 replies.
Page 1 of 1 (9 items)
  • 12-22-2008 8:09 PM
    I am surrounded by hills and want a bike that will climb like a mountain goat.  With all the different Cervelo frame types to choose from, which one would be considered the best climbing bike?
  • 12-22-2008 9:16 PM In reply to
    Re: Which Cervelo is the best climbing bike?
    Carlos Sastre and the rest of the CSC team changes from the Carbon Soloist to the R3 for the mountain stages, L'Alpe De Huez--so the R3 would be the better choice (presumably because of its lower weight).
     Note: I do not know about the new S3. Good luck!
  • 12-23-2008 2:48 AM In reply to
    blackcab:
    R3SL is the bike you want for heavy long climbs but any of the R3, RS series will climb good.
  • 12-23-2008 5:40 AM In reply to
    • mickd
    • Joined on 10-03-2008
    • Posts 14
    Absolutely has to be the R3 SL. The benefits of the ultra light frame are most obvious during a long climb!
    2008 Cervelo R3 SL
  • 12-23-2008 9:47 AM In reply to
    Strictly, it's you who has to climb like a mountain goat. The R3SL will help a lot though.
  • 12-23-2008 12:36 PM In reply to
    • sam
    • Joined on 09-08-2007
    • St. Louis
    • Posts 821
    second all the above, the weight and stiff bottom bracket, equalls a good climbing bike.  Look at the r3/r3sl
    Sam
    Peloton Cyclery
    www.pelotoncyclery.com
  • 12-23-2008 6:54 PM In reply to
    The R3 feels totally at home on a long climb. I've never ridden any of the other Cervelo's but none of them are what you would call 'heavy', so I'm pretty sure the S range would climb pretty damn well too, with the added aero benefits on the flat.
    I'd go with the R3SL if you can afford it.
  • 12-23-2008 8:49 PM In reply to
     Check out the Tech Presentation - Col de la Tipping Point.  There are links to it on the S3 and S2 pages on the Cervelo site.  It covers the whole concept of where weight makes the ultimate difference.  It is well worth a read.
    Cheers
    Andrew
    Velocity Cycle and Ski
  • 12-24-2008 8:31 AM In reply to
    • webmaster
    • Joined on 05-31-2007
    • Mount Livingroom, Toronto, ON - Canada
    • Posts 126
    R3-SL with a nice light set of tubular wheels and a compact crank. It will be a joy to ride up the mountain even when the slopes start hitting 10% or more.
    Cheers,
    Matt.
    webmaster@cervelo.com
    www.cervelo.com
