Cervelo R3 SL / R3 Proud Owners
Last post 03-08-2010 12:48 AM by Rippin. 146 replies.
Page 8 of 10 (147 items) « First ... < Previous 6 7 8 9 10 Next >
  • 10-09-2009 10:08 AM In reply to
    • Lolita90
    • Joined on 09-27-2009
    • BELFORT - FRANCE
    • Posts 70
    Re: Cervelo R3 SL / R3 Proud Owners
     Superb job Leaf, your R3SL is very nice !!
    Lolita
    R3 2009
  • 10-09-2009 11:29 AM In reply to
    • thom_y
    • Joined on 08-13-2007
    • Halifax, NS Canada
    • Posts 408
    OK, let's see some 2010 pix.... Tired of the old paint jobs.
  • 10-10-2009 4:16 AM In reply to
    • Manny
    • Joined on 04-11-2009
    • London
    • Posts 57
    Here's my pride and beauty.
    Size 54.
    1st bike: white R3 2009 size 54, Sram Red + Fulcrum RS crankset, Zipp 404 Tub 2009
    2nd bike: black Caad9 2010 size 54, Shimano 105, Fulcrum Racing 1 black
  • 10-10-2009 2:39 PM In reply to
    • Lolita90
    • BELFORT - FRANCE
    • Posts 70
     Very nice Manny
    Lolita
    R3 2009
  • 10-14-2009 8:19 AM In reply to
    • nycebo
    • Joined on 10-09-2009
    • New York, NY
    • Posts 43
    Just picked up my Cervelo R3 on Saturday morning.  Dura-Ace 7900 Groupset, Shimano Scandium WH-7850-SL tubeless wheels, Hutchinson Fusion 2 tires, swapped out the Arione for a Flight Gel Flow seat and Speedplay Zeros.
    Got in my first ride on it last night.  Light.  Stiff.  Smooth.  Simply loved it.  I'm sure I'll tinker with the fitment over the coming weeks but it is leaps better than my old Cannondale.  Here are the improved photos:
  • 10-14-2009 7:40 PM In reply to
    • mudrock
    • Joined on 01-23-2008
    • Finger Lakes NY
    • Posts 701
    nycebo, I have the Hutchinson tubeless on my Fort, I love them. As the Fusions wear out, I'm replacing them with the Hutchinson Intense, 25mm width and slightly heavier, but longer wearing. Are you using sealant?
    Alex
  • 10-15-2009 8:32 AM In reply to
    • nycebo
    • New York, NY
    • Posts 43
    Hey Alex, I have sealant in the front tire as it was gradually losing air overnight upon installation. The sealant resolved the problem completely. As for the rear tire, it remains sealant free. From what I've read, installation requires a great deal of patience with soap and water to create a really tight seal. Generally, my LBS said it's just easier to dump in some Hutchinson sealant and call it a day. Rides great though. Really like them. Edward
  • 10-15-2009 9:33 PM In reply to
    • mudrock
    • Finger Lakes NY
    • Posts 701
    The hard part is getting the tire on, because the carbon bead is so tight. The soap and water is just to make sure the bead is seated all the way around when you inflate. But that's done already, putting in the sealant is easy. If you do it yourself, just remove the valve core, pour in an ounce of sealant, replace the core, and inflate. Hang up the bike while you do it so the weight of the bike doesn't break the seal of the tire. Especially living in New York, I'd use sealant. It's the best set-up for city riding.
    Alex
  • 10-21-2009 4:53 PM In reply to
    • off
    • Joined on 10-08-2008
    • Posts 20
    Upgraded the bike recently with Rotor Q-Rings, Fizik Alliante saddle and Zipp 404 with Zipp Tangente 700x23 tubbies. As shown 14.5 lbs.
  • 10-22-2009 8:33 AM In reply to
     My 2010 Cervelo R3
    Components:
    - SRAM Rival Groupset
    - SRAM Foce Crank with ROTOR Chainring
    - Fast Forward F2R-240s with Vredestein Fortezza Pro-TriComp
    - 3T Ergonova Team Handlebar and Arx Team Stem
    - Fizik Antares Saddle
    - Weight 6.4kg
    - a proud owner of 2010 Cervelo R3 -
  • 10-22-2009 8:44 AM In reply to
    • nycebo
    • New York, NY
    • Posts 43
    Loving the new colors wangsanegara!
  • 10-22-2009 11:11 AM In reply to
    Hi off. At last I see the Rotor Q Rings on  SRAM cranks. Is the front derailleur up at it's max setting without any interference from the outer ring? And has the shifting been negatively affected?
    A beaut outfit you have there.
  • 10-22-2009 11:48 AM In reply to
    • off
    • Posts 20
    mick.rocket, That is correct, for the 52/39 130BCD Q-Ring's I did have to set the front derailleur to the top position for it to clear. As far as shift quality, I was pleasantly surprised it did not affect it too much. From small to big ring, there's definitely more lag, but it's only a fraction of a second more. The benefits outweigh the negatives with the Rotors!
  • 10-22-2009 11:56 AM In reply to
    • Posts 36
    Here you go:
    '06 R3, Di2, 404 tubbies
  • 10-22-2009 12:23 PM In reply to
    • off
    • Posts 20
    Bobbo, That is an awesome setup you have there. Read about it in the other thread. Let us know how Di2 works out once you've gotten some saddle time with it!
