Small rider, what size do you ride ?
Last post 02-18-2009 1:51 AM by Triskeliongirl. 17 replies.
Page 1 of 2 (18 items) 1 2 Next >
  • 02-05-2009 3:40 PM
    If you are between 160 to 170 cm. high, so please write your total hight, your inseam hight and what size Cervelo you ride...
    Think a size 48 fit's me..
    Thanks
    Henry 165cm., inseam 76 cm.
    Denmark
    CSC Size
    [48]
    Pedersen 48 170 cm.
    [51]
    Sastre 51 173 cm.
    Henry Lerche Madsen
    dansk sprog flag Denmark
    My S2 2009 Sram Red
    I want to buy a used frameset Cervelo SLT size 48 !!!!!! (or equivalent Cervelo with the same geometry )
  • 02-05-2009 5:23 PM In reply to
    Re: Small rider, what size do you ride ?
    5’6” short    (167 cm)
    28.5” (72 cm) inseam, tiny legs, long torso
    137 lbs (62 Kg)
    51size p2c and 51 slc
    SLC road, P2C Tri
    808's race
    Easton while training
  • 02-05-2009 5:31 PM In reply to
    Height: 162.5 cm ... Inseam: 77cm ... Weight: 137lbs. 62kg ... 51cm SLC-SL
  • 02-05-2009 9:11 PM In reply to
    • wdanley
    • Joined on 12-28-2007
    • Evergreen,Co
    • Posts 67
    Height 168 cm. inseam 76.5 and I Ride a 51 R3SL
    bd
    R3SL/Red
    Rolf Elan Areo
  • 02-06-2009 1:52 AM In reply to
     I am 168 cm tall with an 81 cm inseam.  I was fitted on a 51cm R3 last week.  I will pick up my bike next Thursday when they finish building it up.  I can't wait.
  • 02-06-2009 2:21 PM In reply to
    I am 160cm, my inseam is 73cm and I ride a 49 Soloist.
  • 02-06-2009 7:13 PM In reply to
    • BTR43
    • Joined on 04-26-2008
    • Mississauga, Ontario, CANADA
    • Posts 49
    Sorry to ask a question on your post but if a 51cm frame works for a person 160 cm tall, what is the height range for a 48 cm frame?
  • 02-06-2009 7:33 PM In reply to
    M,
    5'5"
    27"
    Measured up at a dealer and I was told a 51cm R3 was told the right size.
    Thing is it's more than just stand over height. I have short legs but a long torso. A top tube length of 52 - 53cm seems to work best, with a short 90mm to 100mm stem. The R3 in a 51cm is the same top tube length as my current Devinci. My cross bike has a virtual 51.5cm top tube and it feels like more of my weight is over the front of the bike so to speak.But it is an XS 44cm frame.  If you are perfectly proportioned, a 48 cm may fit. Personally I would not run a stem longer than 10 cm. If that isn't good look a the size up and compare.
  • 02-06-2009 7:39 PM In reply to
    Likewise, I am curious that no-one is on a 48.  Are people being 'fitted' onto a 51 to avoid the toe overlap problem?  If any small RS owners are reading this, what are your measurements and which size are you riding?
  • 02-06-2009 8:07 PM In reply to
    Let's also remember that if you get into a 48, you are going to the 650 wheels. So you are in a completely different equation, not hating the 650 wheels but 700c tubulars and tubes are far more likely to be available at race day and a loaner wheel will be easy to bum.I rode a 48 and felt pretty good btw, 51 was just better but it does feel less nimble and not as easy to throw around. For long rides, the 51 is the ticket, for me at least feels much more stable.I do have a very bizarre body though, --R
    SLC road, P2C Tri
    808's race
  • 02-07-2009 3:13 AM In reply to
    rodrigo:
    It's only on the RS model that you need need 650C for size XS and the P model's ! S1, S2, S3, R3 and R3SL need 700C in size 48! When Martin Pedersen was riding at CSC he ride a size 48 Soloist, he is 170 cm.
    Henry Lerche Madsen
    My S2 2009 Sram Red
  • 02-07-2009 12:04 PM In reply to
    • Len
    • Joined on 11-27-2008
    • Posts 40
    I'm 168 cm high, 73.5 cm inseam. 51 R3-SL
  • 02-07-2009 9:11 PM In reply to
    172 cm, 54cm SLC-SL, 51cm Super Prodigy
  • 02-07-2009 9:55 PM In reply to
    I'm 170cm, with 31.5 inch inseam.  I ride a 51cm RS.
    Height 163cm, inseam unknown, size 48cm, ride recreational
