Tubeless
Last post 10-13-2009 3:10 AM by Berend. 18 replies.
  • 10-13-2009 1:11 AM In reply to
    Re: Tubeless
    Check this out
    http://luckynino.blogspot.com/2009/03/eclipse-mtb-supertube-56g.html
    I wonder how strong it really is.  If it ever comes to market then it would be worth a try.
  • 10-13-2009 1:32 AM In reply to
    • mudrock
    • Joined on 01-23-2008
    • Finger Lakes NY
    • Posts 701
    Re: Tubeless
    Alex G:
    ...as long as the sealant level is good (I think you have to add some about once a month), you only need to carry a C02 cartridge instead of a pump in the event air is lost from a sidewall puncture (i.e. find the puncture, shake the tire, inflate). One less thing to mount on my frame and I don't have to worry about carrying or installing a new tube on the ride.
    I only add sealant every 4-6 months. I live in western NY where it's not particularly hot. You don't have to add two ounces, either - just one ounce will do.
    Alex
  • 10-13-2009 1:45 AM In reply to
    • mudrock
    • Finger Lakes NY
    • Posts 701
    Re: Tubeless
    Only vulnerability I can see with the Eclipse tubes is a susceptibility to pinching, either during mounting or riding. Sort of like latex tubes in that regard. "The material of the tube is so resistant it is almost impossible to get a snakebite. " Super elastic but super tough. Hard to believe. And you still have to use sealant.
    Alex
  • 10-13-2009 3:10 AM In reply to
    Re: Tubeless
    Jasann:
    Can you put them on a 50mm carbon wheel? From what I see, they only come with small valves.
     Sure you can.  I ride Corima Aero tubeless.  45mm deep rim.  They came with Corima's tubeless valves, which are long enough, and with valve extenders.
