If you had a real fitting done, then either you, the fitter, or both should have a copy of the fit measurements. If they just did a quick fit to help you out then probably not, then you probably are best off the get re-fit as already mentioned.
Deepcover is right that it is ok to play with your fit as time goes on. But I would argue that 95% of the time it is not needed and is not best, as long as you had a good fitter who listens to you and your needs and takes time to work it all out in the fit. But there are those 5% who are so aware of their bodies that they can fine tune the fit very well. So if you play with you fit when you get it where you think you want to leave it, get a check up by your fitter just to make sure you did not do something that will develop a problem.
