you do not need to keep re-tightening the bolt to see if it is level and re-doing it multiple times.
just loosen the rear bolt as much as possible, then turn the front thumb screw, then take your hands and force the front of the seat up with one hand, and force the rear of the seat down with the other hand to see if it is level, re-adjust the thumb screw until it comes out level, no need to keep tightening the rear bolt.
When this post was designed along with others like it on the market, saddles had a higher profile and it was easier to get under the saddle to do things, now saddles have a lower profile making it harder to work on.
