Campy brakes..
Last post 11-14-2009 3:58 PM by fran. 13 replies.
Page 1 of 1 (14 items)
  • 11-12-2009 10:43 PM
    Campy brakes..
     On SRAM and Shimano brakes there is little lever that you flip up to expand them so that you can remove the wheel. On my Campy 11, I've notice that there is no such lever. So how do you remove the wheel if you can't expand the brakes? In the mean time I'm going to look again. Maybe I'm missing something because I can't believe Campagnolo would leave something like this out.
    Update: Never mind...I figured work around. Can't believe that Campagnolo hasn't adapted the Shimano quick release lever.
  • 11-12-2009 11:23 PM In reply to
    Re: Campy brakes..
    1. The quick release is on the brake lever.
    2. It's been that way for ...like, forever.
    3. I agree, it's not as useful as the Shimano system
  • 11-13-2009 12:21 AM In reply to
    • kervelo
    • Joined on 07-25-2007
    • 60° 24', 25° 06'
    • Posts 48
    Re: Campy brakes..
    Actually I think the idea of putting the quick release to the brake lever is better than the Shimano solution. At least for racers: if you have any problems with your brakes dragging to your wheel (due to a crash, broken spoke, etc.) you can easily open the quick release without stopping.
  • 11-13-2009 1:45 AM In reply to
    Re: Campy brakes..
    Good point, didn't think of that (opening up the release when actually riding). For racers, it could come in handy, but the for the rest of the Campy users (probably the majority of Campy owners, myself included) that's not much of an issue. The biggest problem with Campy's quick release is that it is either closed or all the way open - no in between. So if you've bent the wheel a bit you have to deal with a far lever reach when the brake lever release is open.
  • 11-13-2009 9:07 AM In reply to
    Re: Campy brakes..
    kervelo:
    Why would you have to stop to open the QR on a non Campy brake?  It is no problem whatsoever to move the lever on the caliper while riding.  I have ridden with the Campy system and Shimano style and definately think the Shimano type is superior.
  • 11-13-2009 11:52 AM In reply to
    • Lolita90
    • Joined on 09-27-2009
    • BELFORT - FRANCE
    • Posts 74
    Re: Campy brakes..
     I have personnaly adjust the gap in order to remove the wheel without used the brake lever system
    Lolita
    R3 2009
  • 11-13-2009 12:13 PM In reply to
    • fran
    • Joined on 06-03-2008
    • Posts 45
    Re: Campy brakes..
    I wouldn't swap campy's superior stopping power for shimano's quick release system
  • 11-13-2009 12:29 PM In reply to
    Re: Campy brakes..
    I don't know about that..."superior" would be a bit of a stretch. The performance differences between a Campy or Shimano brake system is minimal, probably imperceptible to some. Both provide great modulation and stopping power. Many would actually say that Shimano stoppers are better than Campy. Ahhhh the Shimano / Campy debate goes on...:D
  • 11-13-2009 1:22 PM In reply to
    Re: Campy brakes..
    Rippin:
    If I was unclear, my mistake but what I was saying is that I think the QR system for Shimano style brakes is superior.  There was no inference to any other aspect of the calipers actual braking or modulation performance.
  • 11-13-2009 1:38 PM In reply to
    Re: Campy brakes..
    1406racer:
    No worries, I wasn't referring to your post. I was referring to fran's.
  • 11-13-2009 2:59 PM In reply to
    Re: Campy brakes..
    I've got both Campy & Shimano on diff bikes... I like the look/feel of the Campy brakes better, but prefer the continuous QR cam adjustment of the Shimanos mounted on the caliper instead of the open/close button at the lever like Campy's - 1) I like to run my pads close to the rim so there's minimal 'play' in the braking action, but sometimes when it's wet the rim will pick up debris and start to rub the pads, so I can just reach down and open up the caliper enough to clear the rubbing but don't need to have it open all the way; and 2) you can use them w/ other brands of brake levers (like on a TT bike where the shifters are separate) without giving up the QR feature.
  • 11-13-2009 6:44 PM In reply to
    Re: Campy brakes..
    If your rear brake is rubbing, opening a Campy caliper as you ride is s lot easier than opening a Shimano caliper. I've managed to rub my fingers into a moving wheel a few times doing a Shimano rear on the fly.
  • 11-14-2009 4:08 AM In reply to
    • Joe J
    • Joined on 02-25-2009
    • Glendale, Ca
    • Posts 16
    Re: Campy brakes..
    fran:
    according to this test, shimano and sram brakes outperformed campy in stopping power. http://www.eecycleworks.com/VNJune%20BrakeTest.pdf
  • 11-14-2009 3:58 PM In reply to
    • fran
    • Posts 45
    Re: Campy brakes..
    Thanks for that link it's a really good read I run the old record on mine as I prefer them to the skeletons and I think they preform better,it's the first review I've read that puts campy behind shimano but as some one who boycotts shimano guess i might pick my reading, was thinking of upgrading to kcnc brakes but on that test will probably stick with campy record.Any one out there got any thing good to say about kcnc brakes I run reynolds attack wheels so are they good or not?
