i've just measured some forks i could get my hands on at a local shop, i measured as well pieces of steerers (left overs from cutting) to determine the specific steerer weights:
Wolff CL (302mm steel steerer) : 479g 0.56g/mm steerer, star nut 10g
Wolff SL (310mm carbon steerer): 341g 0.2g/mm steerer, sleeve (75mm) with star nut 21g
Alpha Q (300mm carbon steerer): 326g 0.2g/mm steerer
Easton EC 90 SLX (300mm carbon steerer): 294g
Easton EC 90 SL (300mm carbon steerer): 351g
the interesting thing is that if you substract the whole (visible) steerer off the forks, the CL fork is only 30g heavier than the SL fork, meaning that the blades are probably of similar weight and stiffness
most of the CL steerers i saw were a bit rusty
the Easton SLX fork has been criticized in a couple of magazines for its lack of lateral rigidity, being recommended only for very light riders using very stiff frames
