Is this R3 size 48 ???
Last post 02-08-2010 5:29 PM by greg66. 3 replies.
  • 02-08-2010 10:04
    Is this Cervelo R3 size 48? I thought it appear to be larger. Is there a friendly soul who has a photo of a R3 size 48 for comparison? Thanks
    Henry Lerche Madsen
    dansk sprog flag Denmark
    S2 2009 Sram Red
  • 02-08-2010 2:03 PM In reply to
    • Joined on 11-15-2008
    • Atlantic Canada
    • Posts 362
    Re: Is this R3 size 48 ???
    In the absence of a picture of a size 48 cm, try and measure the effective top tube length, centre to centre, and compare to the Cervelo geometry chart.  If the pictured frame is a size 48, I don't think your measurement will leave you with any doubt. If it is a 51 cm and you think it should be a 48 cm, when you measure you will have doubt about whether the tape measure was positioned correctly (if this makes any sense).
    I don't recall what a size 48 cm R3 looks like but a size 48 cm S2 has the top tube and bottom tube merging together before entering the head tube.
  • 02-08-2010 2:30 PM In reply to
    Sorry but i don't have the frame, but want to buy it. The seller say that the headtube is 120mm. so have to be a 51 !
    Henry Lerche Madsen
    S2 2009 Sram Red
  • 02-08-2010 5:29 PM In reply to
    MacLerche:
    yep. 120 = 51. IIRC, the frame size is stamped on frame around the RD hanger.
