Picture of your Cervelo
Last post 07-29-2010 12:23 AM by goodshot. 3760 replies.
Page 191 of 251 (3761 items) « First ... < Previous 189 190 191 192 193 Next > ... Last »
  • 10-26-2009 11:17 PM In reply to
    Re: Picture of your Cervelo
    leadarrow:
    Mega311: If i could have justified the extra money, I probably would have exactly the same build as that. Maybe except the tires, as I don't know Bontrager tires at all. Good to see.
    Bontrager makes decent tires. Those that I have on there now are my training tires. They are triple puncture, non-foldable, and pretty heavy. I am hoping they last many miles. Thanks for the comment!
    09 R3 w/ Red
  • 10-27-2009 6:39 PM In reply to
    Here's my new frame, the S3 Olympic limited edition.
    I got it today after upgrading my S2 replaced under warranty.
    It sports a DA 7800 crankset, and otherwise an Ultegra SL groupset.
    I'll consider painting the black fork white, but I kind of like the salt & pepper look the bike has now.
  • 10-27-2009 9:27 PM In reply to
    sweet S3. it must be cool to have a frame that you rarely see. i've only seen one and that was at my lbs.
    '08 Ano SLT
  • 10-27-2009 10:34 PM In reply to
    • Julian13
    • Joined on 10-17-2008
    • Vancouver, BC
    • Posts 400
    Got to have the legs as well as the bucks to ride that paint scheme, I don't have either!
  • 10-28-2009 2:44 AM In reply to
    • ouyang
    • Joined on 10-28-2009
    • Posts 3
    Here is my S1, the frame is rock solid. The old Zipp 303 is mounted recently, it works pretty well with aluminum S1 ^^
  • 10-28-2009 6:07 AM In reply to
     What size frame and seat do you have? Love the color scheme you have going with the wheels!
  • 10-28-2009 7:30 AM In reply to
     Hi Ouyang, nice bike.
    By the way, from the background Map, it seems to be you are located around a very nice trail.
    Andreas. W
    - a proud owner of 2010 Cervelo R3 -
  • 10-28-2009 8:08 AM In reply to
    Re: 2010 Cervelo R3
    I have the same bike to yours @wangsanegara ;)
    I bought a month ago the 2009 model R3 and I have the same FFWD wheelset. I have a SRAM RED group and it weights 5,9 kg without pedals. What weight is yours?
    Marko
    Proud R3 2009 owner
  • 10-28-2009 9:15 AM In reply to
    Re: 2010 Cervelo R3
    Hi Marko,
    Mine weight approximately 6.4kg, includes pedal, sensors, wheel magnets, and bidon.
    The setup really climbs like a mountain goat...
    Andreas. W
  • 10-28-2009 9:25 AM In reply to
    • SLC
    • Joined on 10-24-2009
    • Posts 24
    Mega311:
    leadarrow:
    I bought a set of Bontrager tires once, and I could not ride them at all.  The center of the tire was raised up like 2mm 3mm wide, and when I leaned over in a turn it felt like I was falling off of a tectonic plate or something.   It was horrible.  Thankfully the LBS took them back after 50 miles, and I got the Krylions I really wanted that they were out of.
  • 10-28-2009 12:52 PM In reply to
    • Lolita90
    • Joined on 09-27-2009
    • BELFORT - FRANCE
    • Posts 74
    Re: 2010 Cervelo R3
    wangsanegara:
    Hi Marko,
    Andreas. W
    Mine weight 6,8kg including Campi Record, pédals and aluminium wheels (Mavic ES).
    I'm awaiting for a pair of carbon wheels and I expected to arrive about at 6,4kg
    Lolita
    R3 2009
  • 10-28-2009 1:16 PM In reply to
    Re: 2010 Cervelo R3
     Mine is 7.5 kg.... I cannot figure out why though... I have full red... anybody with a similar set getting 7.5kg? ... my pic is posted above...
    09 R3 w/ Red
  • 10-28-2009 1:41 PM In reply to
    Re: 2010 Cervelo R3
     Seat -> SLR =- 100g, to AX Lightness = -180g
    Wheel= EA ~1700g ->  any 1400g pairs like Hed (or tubulars) =-300g
    Your tyres must be heavy -> Michelin Pro 3 Race
    Brakes to Zero Gravity= -70g
    Chain to Record 10s -20g, Cranks to Record -70g
    Pedals? What model? Any Speedplay cuts bit.
     I build lot of light Cervelo's...
  • 10-28-2009 2:02 PM In reply to
    • BMAN
    • Joined on 08-03-2008
    • Cloverdale, Canada
    • Posts 155
    Re: 2010 Cervelo R3
    My 2008 SLC with Sram Red and clincher wheels comes in at around 6200g's give or take a bit. 7500g is pretty heavy with Sram Red so I would guess your wheels are tanks.
    I actually think that my P2K that I am building up will be about 7500g's when completed.
    Aero and Light is Right.
  • 10-28-2009 2:29 PM In reply to
    Re: 2010 Cervelo R3
    Mega311:
    Are you sure it is really 7,5 kg? Does your libra work well? My R3 is very similar to yours, but weights 6,3 kg with pedals, polar, bidon and FFWD wheelset. FFWD tubular set weigths only 1040 g, your Easton set weights much more I think, but 7,5 is too much I think.
    Proud R3 2009 owner
