Picture of your Cervelo
Last post 01-09-2009 5:36 AM by Mr R3. 1393 replies.
Page 52 of 93 (1394 items) « First ... < Previous 50 51 52 53 54 Next > ... Last »
  • 06-23-2008 12:48 PM In reply to
    • Karuna
    • Joined on 06-20-2008
    • Posts 6
    Re: Picture of your Cervelo
    Roobay:
    Heres a link to my photobucket account theres pictures of ALL may rides in there ..... enjoy (didnt really want to spoil the Cervelo theme)
    Thanks for the nice comments too!
    jr
    http://s263.photobucket.com/albums/ii156/johneroberts/
    Roobay, WOW, Awesome set of bikes! Can you compare your experience of the ride quality and performance of the Cervelo R3 vs the Parlee Z4. I own the 2008 R3-SL and I've been very curious about that Parlee Z4. Thanks a lot.
  • 06-23-2008 3:00 PM In reply to
    • Roobay
    • Joined on 10-05-2007
    • Clent Hills
    • Posts 112
    Well up until i got the Parlee i thought that my favourite
    > bike was the R3!
    > And I've been a Cervelo user for 4-5 years before the
    > R3 i had R2.5
    > Its simple really if you want a bike that you can ride over
    > 6 hours then buy a Parlee or an R3
    > If you want a very fast bike then the snappy SLC-SL, but be
    > warned this bike is hard to ride for long periods.
    > Differences between Z4 and R3 in my opinion are the R3 is
    > little more stiff which can equal "Harder" its
    > also dependent on what forks you use too, my first R3 had
    > Wolf forks and now i use AlphaQ, something i added when i
    > built the bike. I didn't want the the Easton or the T3
    > forks as standard.
    > The parlee however  is a great all rounder has degree of
    > comfort ive only dreamt of (my friend has a Colnago C50 and
    > he feels the same about that)
    > Im very lucky to be able to afford all these different
    > bikes, but if i had to choose one....
    > Parlee Z4
    > Hope this helps
    > Cheers
    > john
    Parlee Z4 2008
    Cervelo R3 2008
    Cervelo Soloist SL 2007
    Litespeed Vortex Compact 2007
    Litespeed Archon 2008
  • 06-23-2008 7:00 PM In reply to
    • richwatty
    • Joined on 05-18-2008
    • Oundle, UK
    • Posts 1
    My new ride, it was great fun deciding what components to fit but it is even better to ride. 7.2 kg as pictured.
    Soloist carbon, Campy Record, Zipp 404
  • 06-23-2008 7:33 PM In reply to
    OK, here's mine... Got the frameset over a month ago and mostly swapped the existing trim over from my previous TT rig (only a couple new replacement parts/upgrades in the process), but had a variety of unrelated conflicts so it took until last weekend to finally get it out for the maiden ride.  Still need to dial in the position a little better for comfort over longer events, but already lowered my previous best mark on one of the local timed loops (by almost a minute over a little less than 40K) even with the training wheels/tires and without the full-on TT kit (no aero helmet, shoe covers, etc).  "Aye, she's fast, Captain!"
  • 06-23-2008 10:40 PM In reply to
    What size is your p2c mike?
  • 06-24-2008 6:51 AM In reply to
    Mike, What wheels do you have on that beauty? Also, how do you like the Arione saddle? Have you had that saddle before or is this your first Arione? The bike looks great mate.
    Michael
    Cervelo P2C
  • 06-24-2008 12:35 PM In reply to
    Size is a 58.  I considered a 56 (I'm 6-1 w/ 34" inseam) but decided on the 58 to raise the front end up a little higher, w/ a shorter stem to offset the extra reach.  Even w/ that, it's still a little lower in front than my previous TT ride... no doubt it's faster, but it's taking a little getting used to the extra strain in the glutes & hammys from bending down more.
    Wheels are older, pre-dimpled Zipp 404's (sorry, Redcorn) w/ the decals removed.  I weigh ~175 and have toasted a few wheels over the years, but I'm usually pretty careful and haven't had any problems w/ these yet, only using them for races.  Got a good deal on them after the dimpled versions came out, otherwise ~$2K wheels just ain't in the cards for me.  I'm looking at a cheaper/lighter conventional-build Al-rim wheel w/ a disc cover to put on the rear for flat races next.
    Had the Arione less than a full season so far; it's actually the Tri 2 model w/ the extra nose padding.  Prior to that, I rode the SLR T1.  Kinda mixed on the two... I like the extra length and "flatter" (less sculpted) shape of the Arione, good for scooching fore/aft on the fly to adjust slightly for fatigue and/or variations in wind/terrain.  On the minus side, it's not as forgiving on my sit bones; the T1 was definitely softer, especially up forward on the nose, but then the trade-off was most of the time in the mid-position the nose felt too wide so I was either pedaling "bowlegged" or rubbing too much.  I realize engineering both extra cush and narrow profile are somewhat exclusive, so the quest for perfection continues...
  • 06-24-2008 5:22 PM In reply to
     Hi guys I have two bikes for you to look at but it's difficult to post them here1 I'll work it out if I can be bothered to do so ......probably not! Anyway I own a P3C with Corima Aeros, FSA bars & stem Selle Italia saddle and full Camapagnolo Record groupset. This bike is amazing I have smashed all my PB's on it ! The R3SL was bought on the back of my impressions of the R3SL.  I have just taken possession of a R3SL with Campy Hyperon wheels , Record g/set and Supergood kit at 6.5Kg. When I work out thr pictures thing I will post the pictures
  • 06-24-2008 6:03 PM In reply to
    treefrog:
    If you use a free online picture host like www.imageshack.com they will give you a link to post here in the forums so your pictures will show. Here are the steps.
    1. Sign up with www.imageshack.com It is free. www.photobucket.com is another one.
    2. take your picture with your camera and load it to your harddrive and remember where the picture is.
    3. Open Imageshack or photobucket with your internet browser and tell it to upload your picture with the resize it to forums option. The picture will be uploaded to imageshack or photobucket and several different links will be given to you.
    4. Open a post here on these forums and look for the button that has a tree picture, its the only one that is green where you can do spell check and such when you are opening your message, it will ask for a html link which imageshack has given you, just clip and paste link that imageshack has, the one that says direct html link into that slot and you are done.
  • 06-25-2008 12:56 AM In reply to
    OK ... Its not about what you have, but what you do with it. My bike is a humble ST, and my marriage would probably never survive a fancy finishing kit. But, boy, does that bike spoil me. Here are some pictures of our outing this long, summer evening. Let's see more of where and what you ride!
    We started  by the seaside:
     And then climbed
     and climbed
    until we were rewarded with a view, followed by a screaming descent back to sea-level.
  • 06-25-2008 1:22 AM In reply to
    Good idea, DeepCover on posting pics of where we ride. I'm guessing some of the pics should have our Cervelo in it since this is a Cervelo site. Maybe you should start  a new thread of Pictures of Where you Ride with the pics you just posted. I'm sure everyone will post to it.
    Check out bikejournal.com
    I chase coyotes up hills on my Cervélo SLT.
  • 06-25-2008 4:12 AM In reply to
    • RMW
    • Joined on 07-13-2007
    • The Netherlands
    • Posts 105
    Got my SRM wireless installed last week.  This is maybe the only piece of gear redcorn doesn't have yet  ;-)
    dura ace wireless
    LOVE these bearing
    enduro
  • 06-25-2008 8:35 AM In reply to
    Deepcover, Very nice views. I looks like you make the most of your rides. That is what it is all about- you are correct. By the way, Where are these pictures taken? It looks like an awesome town,
    Michael
    Cervelo P2C
  • 06-25-2008 12:05 PM In reply to
    michaelmorar:
     Its North Vancouver, British Columbia, Canada. I live an area called Deep Cove.
  • 06-25-2008 2:59 PM In reply to
    Here is my Carbon soloist w/ Dura Ace, Xtreme 83mm Wheels, Easton EC 90 bars, and my New Custom Painted Fork to match the rest of the bike.
