Picture of your Cervelo
Last post 01-09-2009 5:36 AM by Mr R3. 1393 replies.
Page 53 of 93 (1394 items) « First ... < Previous 51 52 53 54 55 Next > ... Last »
  • 06-25-2008 3:33 PM In reply to
    Re: Picture of your Cervelo
    Ok, I'll ask, why the dual seatpost in the forward position?
  • 06-25-2008 3:40 PM In reply to
    bbgobie:
     It makes things easier riding in the aero position. Note the aero bars.
    Check out bikejournal.com
    I chase coyotes up hills on my Cervélo SLT.
  • 06-25-2008 3:48 PM In reply to
    Oops missed it. The big ol hoods were in the way!
  • 06-25-2008 3:57 PM In reply to
    I have an RS and have always been 'curious' about aero bars.....do you have to change anything regarding fitting when you add aero bars?  If you have your riding position without aero bars perfect, are you going to have 'adjust' saddle height and/or fore/aft position or adjust bar height/rotation, etc. etc.?
  • 06-25-2008 4:24 PM In reply to
    Depends on how you intend to use them... I've had aero bars on a regular roadie before, too.  If you want to maximize the aero benefit for Tri/TTs, then you'll need to rotate your upper body position lower/flatter by moving the seat forward (which usually also means adjusting the height/tilt to compensate).  But, I've seen aero bar set-ups on long-distance tours as well, maybe partially for efficiency but more to relieve some of the pressure on the hands and resulting shoulder/neck strain by allowing you to put the weight on your elbows/forearms part of the time.  In that case, you don't necessarily want to change your pedaling position, but you'd likely need to raise/shorten the stem to decrease the reach to the elbow/forearm pads.
  • 06-25-2008 4:54 PM In reply to
    tridawg, what size is your carbon soloist?
  • 06-25-2008 5:01 PM In reply to
     The Soloist is a 58 and I use it primarily for Triathlons.  I have a seperate base bars / aero brake and use the clip on and add bar end shifters for some tris.  I have the seat post in the forward position and keep it there most of the time as I have become comfortable in that setup.
  • 06-26-2008 6:33 PM In reply to
    I slapped on some white handle bar tape. I'm curious if it cleans easily. I'm sure I'll find that out tomorrow.
     I'm waiting for my matching Pro Race 3's to come in. :)
  • 06-27-2008 1:39 AM In reply to
    seven.62:
    Fizik white tape is the only tape I use because it lasts a long time and doesnt absorb oils and stains. It will wipe off clean. Michelin Pro 3 tires are awesome they are my favorite clinchers.
  • 06-27-2008 1:48 AM In reply to
    And that's exactly why I picked up the Fiz tape. I read it cleans up nicely and it's pretty tough tape. I'll use some diluted Simple Green to clean it up when the times comes and see how that works.
    I've got the Pro 2's which I really like. Can't wait to try out the 3's.
  • 06-27-2008 2:56 AM In reply to
    seven.62:
    I just use windex wipes on all bike parts and everything comes off great.
  • 06-27-2008 10:48 AM In reply to
    Redcorn:
    I can see Redcorn now...
    This kind of garbage is way OT for the Picture Your Cervelo thread.
  • 06-27-2008 5:11 PM In reply to
    thats funny :) I love my windex wipes.
  • 06-27-2008 5:37 PM In reply to
    2008 Cervelo SLC-SL 61cm
    Sram Red Crankset 53/39
    Sram Red Cassette 11/26
    Sram Red Shifters
    Sram Force Front Derailleur
    Sram Force Rear Derailleur with Ceramic Jockey Wheels
    Sram Force Brakes with Swiss Stop Yellow Pads
    Custom Ergott/Reynolds/Tune/Sapim Carbon Clinchers - 1400 grams
    Easton EC90 Equipe Handlebars 44cm
    Ritchey WCS 4-Axis Stem 120mm
    Ritchey WCS Pro Peloton Pedals
    Selle Italia SLR Saddle
    KMC X10SL Chain
    Michelin Pro Race 3 Tires
    Michelin Aircomp Tubes
    Cateye Micro Wireless Computer
    Karbona Bottle Cages.
    15.00 Pounds ready to ride as shown.
  • 06-28-2008 7:11 PM In reply to
    I'm pretty interested to hear how easy it is to keep that tape clean, and how comfortable it is. I'm using some Deda gel stuff, which is super-comfy.
    I've never been able to change a tyre without ending up with black hands. Unless it was vinyl, I can't see how white tape would survive the ride after that.
