Soloist seatpost nut failure
Last post 02-10-2012 3:12 PM by Gordo. 4 replies.
Page 1 of 1 (5 items)
  • 02-03-2012 6:23 PM
    • Gordo
    • Joined on 02-03-2012
    • Posts 2
    As most of you know, the Soloist seatpost can be changed to either a road or tt/tri position. The seat rails are clamped in place by a bolt and a bolt with a flanged nut.
    While adjusting my saddle last night, the nut failed (both flanges were sheared off when I was tightening it.) And while I found a replacement seatpost head online:
    http://www.excelsports.com/main.asp?page=8&description=Seatpost+Head&vendorCode=CERVELO&major=1&minor=19
    It aggrieves me to have to pay 20 bucks for a ~15 cent nut.
    Anyone know of a Cervelo small parts source? I find it astounding that a 15 cent nut can render a $2000+ bike un-ridable...
     Cheers from Victoria BC, Canada
  • 02-03-2012 8:46 PM In reply to
    Re: Soloist seatpost nut failure
    Give nytro a call. They had a rear brake internal cable stop for my s1 frame. http://www.nytro.com/
  • 02-03-2012 9:03 PM In reply to
    • racewatcher
    • Joined on 09-09-2011
    • Newfoundland and Labrador
    • Posts 80
    Another option is to check out a specialty machine or parts shop that may have similar bolts for a few cents.
    racewatcher
  • 02-04-2012 10:36 AM In reply to
     I was able to source the bolt at Home Depot of all places - - it doesn't use any unique thread pitch so I just matched it and was back in business.  Actually I went with a hex-head bolt and was able to tighten it through my saddle cutout (at the time, different saddle now) FAR easier than the standard bolt.
     Hope this helps.
  • 02-10-2012 3:12 PM In reply to
    • Gordo
    • Posts 2
    Thanks everyone for all your suggestions. I bit the bullet and ordered 2 seat post heads from ExcelSports. I figured in 3 years time (~when the next nut fails) this part will be impossible to find without a hack so I figured I'd stock up a little.
    Cheers
