Cassette change question on 2013 R3
Last post 05-08-2013 1:54 PM by racewatcher. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • 02-12-2013 1:39 PM
    Just recently picked up a 2013 R3 Ultegra which comes stock with a 52/36 sprocket and 11-25 cassette.  I ride some hilly areas and am trying to keep my heart rate down so am planning to move to a 12-30 cassette.  Do I need to change anything besides the cassette or bolt in (with some adjustment) and go?
  • 02-12-2013 3:26 PM In reply to
    Re: Cassette change question on 2013 R3
    Unless I am missing something, this should be a straight forward swapping of the cassettes.
    2015 R5 Dura Ace
    2012 S5 VWD Dura Ace Di2
    2011 R3 Dura Ace
    Zipp 303 Firecrest Clinchers
    Zipp 303 Firecrest Tubies
  • 02-12-2013 4:03 PM In reply to
    You "may" have a couple of minor issues...
    1) I believe Shimano lists a max 28T on the Shimano short cage RD, but I'm not sure if that will present a big problem considering it's just an extra 2
    2) your chain length will likely be a bit short, it "may" work in some combos, but once you get over the 25T it may feel a bit "draggy" (mainly in the big ring)
    Just as another suggestion, the 28T might be enough for your hilly rides, so outside of a longer chain the RD will be fine.  Also, lets say the 36x28 is not low enough for your hilly rides, last resort will be to swap for a 50/34 chainring combo, which will work on your existing 110BCD (bolt circle diameter) compact cranks.
  • 02-12-2013 4:05 PM In reply to
    Can you post pics of your R3?  I have yet to see one in person and pics on the web are mostly stock ones.  I'm curious if the silver is shiny or matte.  Thanks!
    Cervelo R3, Specialized Tricross, Eighthinch Fixie
  • 02-12-2013 4:27 PM In reply to
     It's a shiny finish.
     And most likely I will pickup some Praxis 50/34 black chainrings so I don't need to worry about it.
  • 02-12-2013 5:17 PM In reply to
    Go 50/34 and 11-28 and you won't regret it for the mountains.
    And the 4% higher cadence probably will go almost unnoticed  unless your holding
    35 mph on the flats.
    Aloha,
    Jeff
    2014 R3 DA9070(Di2)Zipp404Firecrest Carbon Clinchers, Powertap SL+-SoCal
    2010 P2 DA/Ultegra-SoCal Zipp808 Firecrest Carbon Clinchers, Zipp Super 9 Carbon Clincher Disc
    Zipp 202 Firecrest Carbon Clinchers
    Pivot 2015 Mach 4 Carbon (27.5) M9000 XTR Reynolds Black Label XC wheels.
  • 02-12-2013 7:38 PM In reply to
     thanks, it looks great! what size frame is that?
  • 02-12-2013 8:10 PM In reply to
    SteveFromNYC:
    It's a 48.  Initially I was going with a 51 with a shorter stem, but for sizing the fitter had me try a 48 and it fit me like a glove so the fitter kept me on the 48.  Anyhow, I love the look of road and mountain bikes when seat post is high up there above the stem.
  • 02-13-2013 4:06 PM In reply to
    Hutch:
    So the Short Cage derailleur comes stock on the bike?  How can I tell?
  • 02-13-2013 8:08 PM In reply to
    I think a 50/34 chainring and 12/25 would be a very good setup. If you just bought the bike maybe see if they would swap chainrings? the cassettes are usually cheaper an easier to change later if you still feel the need. Also good to have 2 cassettes if you get another wheelset.
    2013 Pinarello Dogma 65.1 Super Record EPS
    2012 Cervelo RS Dura Ace C24s
    2012 Cannondale Flash 1 29er
    2013 Felt 65x CX bike
  • 02-13-2013 10:22 PM In reply to
    ApexR3:
    Hutch:
    Comparison below... really it's all about the length of the cage.
    I believe even the short cage "may" work with a 30T.  Typically you see the long cage RDs with triples instead of doubles.   However the total capacity or chain wrap for that Ultegra short cage RD is 33T, the way you calculate it is below...
    In your case with what you want to run (52 - 36) + (30 - 12) = 34, that's why going with an xx-28T cassette will be optimal for best shifting performance in all combinations.
  • 02-14-2013 3:18 PM In reply to
    Thanks for the images.  I contacted my LBS and they said to go with an 11-28 since the derailleur is the regular short cage and not the 6700A short cage.  The pivot points are different on the 6700A to work with the 12-30 cassette.  I'll see how things go with the 52/36 - 11/28 combo goes and if I need more help on the hills I'll go with 50/34 chainrings.
  • 04-10-2013 1:22 PM In reply to
    • racewatcher
    • Joined on 09-09-2011
    • Newfoundland and Labrador
    • Posts 215
    That's what I just did. I had 11-25, and put on an 11-28 cassette to go with my 50/34 up front. All it took was to swap the cassette, and check derailleur adjustment, especially high and low limit screws to keep the derailleur out of the spokes. Check cable tension and away you go. The short cage will handle 28 teeth, I'm not sure about 30, it might be a bit of a stretch for a short cage rear mech.
    racewatcher
  • 04-10-2013 9:00 PM In reply to
    Great looking bike! Congrats and enjoy the ride.
  • 04-11-2013 6:27 PM In reply to
    • spotter
    • Joined on 10-17-2008
    • Newcastle, Aust
    • Posts 143
    Just put on the 11-28 for the http://www.b2b.asn.au/ , normal run 11-23.
    Was very weird ridding in to work this morning, didn't get out of the Big Dog (well 50T not that big) and spin baby spin. Glad I will have a few more rides over the weekend to get use to it.
