New Cervélo, in between sizes, which one to choose?
Last post 05-30-2013 10:09 AM by Velo E. 14 replies.
Page 1 of 1 (15 items)
  • 04-23-2013 2:38 PM
    • The.Wolf
    • Joined on 04-23-2013
    • Ottawa, ON / Montreal, QC
    • Posts 2
    I am currently in the process of buying a brand new Cervélo R3 2013. I am 170 cm with a 76cm inseam. At my lbs, the seller told me I'd be good for either a 48 or 51 cm frame He then strongly advised me to go with the 48. He had both in stock. The bike will be mainly used for 60 - 80 weekends rides or occasional 100 + km Also, 35 km commuting. I have a fitting scheduled Thursday afternoon and just wanted to make sure that I was heading in the right direction. What would be the impact of the smaller frame? Thank you
  • 04-23-2013 2:48 PM In reply to
    • jdais
    • Joined on 09-10-2008
    • Long Island, NY
    • Posts 737
    Re: New Cervélo, in between sizes, which one to choose?
    If you can fit the 51 without feeling overstretched, then go with 51.  48 might not fit larger waterbottles and may require you to use 650 wheels
  • 04-23-2013 3:07 PM In reply to
    • Posts 443
     I am the exact same size as you and I have a 51cm...(also have a 54cm which is fine but needed 90cm stem instead of stock 100cm)
  • 04-23-2013 3:19 PM In reply to
    I agree get a the bigger bike for the water bottle issue
    2011 S3
    2011 R3 (Warrantied)
    2014 R3
    Garmin 800(RIP)
    Garmin 1000
    2014 Beyond the Forum Rider
  • 04-24-2013 8:06 AM In reply to
    I had the same choice to make. The headtube on the 48 is a fair bit shorter and I'm not very flexible so unless you want to get a very low riding position you may be better off with the larger frame.
  • 04-24-2013 9:51 AM In reply to
     I had the same decision and went with the larger frame to avoid the limited 650 wheel options. In my preliminary searches, due to limited availability of 650s and even more limited demand, when you find a sale on wheels they tend to be very good sales, but otherwise tough to find.
     As a result I ended up using a stubby 70mm -6 degree stem on my 51cm.
    2012 R3 Team - Ultegra - Hed Jet 5 Express - Garmin 910xt
    2011 R3 - Ultegra - Dura Ace C24 (RIP)
  • 04-24-2013 10:38 PM In reply to
    • The.Wolf
    • Posts 2
    I did not even think about the wheel size being an issue! Thank you for that! I called the shop and they told me they could hold the 51 for me until the fitting tomorrow so I can choose.. With this in mind, I'm pretty sure I'll go with the 51cm! Thanks everyone!
  • 04-24-2013 10:50 PM In reply to
    Based on your measurements, 51cm probably works better for you but just on a side note if you end up with a smaller frame - I ride 48cm S2 with regular wheels (700). No issues at all (toe overlap never been an issue...) In terms of water bottles - yes the tall ones won't fit in the downtube. Regular ones, no problem.
  • 04-25-2013 1:20 AM In reply to
    I am 171 with 81 inseam and riding a 51 S2.
  • 04-30-2013 9:48 AM In reply to
    • racewatcher
    • Joined on 09-09-2011
    • Newfoundland and Labrador
    • Posts 215
    I'm 167 on a 51 cm S2. Can you ride both and see how it feels?
    racewatcher
  • 04-30-2013 12:53 PM In reply to
    I am 5'6.5" (167.4cm) and 30" (76cm) inseam which is about your dimensions and I went with a 2013 48cm which comes with 700c wheels.  I have no problems with the long Camelbak insulated water bottle fitting in an Arundel Mandible cage in the seat tube.  I think if you went 51 you'd be too stretched out - at least I was.  I test rode the 51 first and then the 48.  Immediately, the 48 just felt right - like a glove.  Test rode the bikes (48 and 51) back to back again and again and the 48 always felt better.
    I could have gone with a 51, but then I'd have to shorten the stem and also move to a 0 offset seatpost.  With the 48 I didn't have to adjust anything.  Even with the 48, I have to run my saddle more forward than normal.  The only thing with the 48 is the head tube is short so I have quite a bit of spacers under my stem.
  • 05-29-2013 3:46 PM In reply to
    • wayne
    • Joined on 05-29-2013
    • Posts 5
     Body build is an important consideration. A small bike frame set up for a correct reach and seat height will flex more under load with a heavy rider. A lonver stem and seat post extension adds leverage to the riders weight and strength. Conversly, a light rider on a larger frame will stress the frame below the design and will feel rigid and dead.
     If possible, ride them both.
  • 05-30-2013 5:21 AM In reply to
    • Posts 974
    Not true. I'm sure the difference in feel is about size and geometry, not how much flex there is.
    2015 COR
  • 05-30-2013 8:01 AM In reply to
    • GT1
    • Joined on 09-26-2008
    • Posts 934
    wayne:
    +++1
  • 05-30-2013 10:09 AM In reply to
    Both of these frames have 700 C wheels. That is not a factor for you. Where the frames really differ is the head tube angle (they have the same fork rake) and the stack (which is a 25 mm difference). The reach difference is only 9 mm which can be taken up easily in short reach bars or a stem change. If you can handle the difference in stack (this is usually my limiter personally) then you will probably want the smaller frame since the fork rake and head tube angle offset each other more to solidify the handling (i.m."rarely"h.o.) and it will put your butt farther over the rear tire and keep the back of the bike planted. It will also give you more stand over height (crotch clearance is always a good thing). If you do go with the smaller bike you should be sure to check that the biggest water bottles you want are fit to use in the frame, this can be a problem with smaller frames. After the fit you should check the toe overlap on the smaller frame. There is not a problem even with toe overlap for most riders in most situations but be sure you are comfortable with it.
