S2 size advise
Last post 05-20-2013 8:36 PM by Jtan. 6 replies.
Page 1 of 1 (7 items)
  • 05-16-2013 11:51 AM
    • Jtan
    • Joined on 05-16-2013
    • Posts 3
    S2 size advise
    I am about to purchase my first Cervelo, a second hand S2. I received a conflict info on the size that I should buy. LBS said I should go for 51, my fitting guy said 48. I am 5'6" inseam 28.5" What size should I buy?
  • 05-16-2013 11:52 AM In reply to
    • S Berg
    • Joined on 07-07-2011
    • Denver, CO
    • Posts 53
    Re: S2 size advise
     why would you not listen to what your fitting guy advised?????
    2011 R3 - Dura Ace
  • 05-16-2013 12:01 PM In reply to
    • Jtan
    • Posts 3
    Re: S2 size advise
    My friend who rides S2 said the Cervelo dealer might know better. My fitting guy is a really good one, though.
  • 05-16-2013 7:51 PM In reply to
    Re: S2 size advise
    My GF is 5'6" and she is on a 51cm S2. I am 5'8" and on a 54cm S2. The 48cm will have a really short head tube. If you are not that flexible...you could end up with a big stack of spacers under the stem.
    S2 SRAM Red
  • 05-16-2013 8:43 PM In reply to
    • racewatcher
    • Joined on 09-09-2011
    • Newfoundland and Labrador
    • Posts 215
    Re: S2 size advise
    I'm 5'6", 30 inch inseam, 155 lbs, on a 51 cm S2.
    racewatcher
  • 05-17-2013 11:40 PM In reply to
    • Joined on 11-15-2008
    • Atlantic Canada
    • Posts 748
    Re: S2 size advise
    For 5'6", your inseam of 28.5 inches if measured from crotch to the floor without shoes is relatively "short". This may be one of the reasons why your fitter recommended the size 48 S2. Only you and your fitter can assess your flexibility. Stem length, angle, amount of spacers below the stem as well as handlebar drop and reach are other considerations for your fit on the bike.
  • 05-20-2013 8:36 PM In reply to
    • Jtan
    • Posts 3
    Re: S2 size advise
    Thanks to all, I am going for 48 per my fitter recommendation.
