Just converted R5ca from external to internal routing
Last post 12-02-2014 10:10 PM by trex021. 7 replies.
Page 1 of 1 (8 items)
  • 12-02-2014 2:50 PM
    • Rick
    • Joined on 07-24-2011
    • SoCal
    • Posts 241
    'Drilled' out 4 holes in the frame plus 2 in the outer BB shell to run Shimano Di2 system. Still external battery though - reason for 4th hole. Cut off the shifter bosses at the front of the downtube as well as the RD boss on right chainstay. Now I need to go out and pick up a rattle can of black paint. Nice and quiet drivetrain now, smooth and clean!
    2011 Cervelo R5ca (56cm): Shimano 6870 Di2/9000 Di2/EWW01 Wireless, Rotor Q-Rings, Dura Ace 9000 C-24.
    2010 Giant TCR Advanced SL Pro (M/L): Shimano 9000 Dura Ace, Shimano Dura Ace 9000 C-35 Wheels.
    2018 Trek Madone 9.4 (56cm): Shimano Dura Ace 9000.
  • 12-02-2014 4:55 PM In reply to
    Re: Just converted R5ca from external to internal routing
    I am impressed and confused all at the same time. Impressed that you did it even more impressed that you did it on a 10k frame which is the confusing part for me. I would never have stuck a drill to it! Kudos to you! PICS PLEASE!
    2011 S3
    2011 R3 (Warrantied)
    2014 R3
    Garmin 800(RIP)
    Garmin 1000
    2014 Beyond the Forum Rider
  • 12-02-2014 5:11 PM In reply to
    • Rick
    • SoCal
    • Posts 241
    Actually a dremel end mill. The guy that did most of the work is the guy that actually built the frame. He did the design analysis on it and it has his blessing. Besides, its the only extra frame I have.
  • 12-02-2014 5:17 PM In reply to
    Rick:
    Nice doe Don G did it ! We need pics
    2011 S3
    2014 R3
    Garmin 800(RIP)
    Garmin 1000
  • 12-02-2014 6:08 PM In reply to
    Very nice Rick. I remember when Don did a couple of them. They turned out nice.
  • 12-02-2014 7:02 PM In reply to
    • Rick
    • SoCal
    • Posts 241
    Yes, Don G did the work :-) Nice, clean job!!
    Step 1 - measure Shimano oval grommets
    Step 2 - decide where to place openings, then mask off with tape where to use endmill
    Step 3 - Dremmel out holes, use fine file, then sandpaper
    Step 4 - Big hole in BB outer shell (do not damage inner shell) for junction box
    Step 5 - optional - use Dremmel cut off wheel to remove Der cable guides
    Step 6 - run wires
    Step 7 - put new components on.
    I got a couple pics, where to post them?
  • 12-02-2014 7:22 PM In reply to
    • Rick
    • SoCal
    • Posts 241
    http://i48.photobucket.com/albums/f244/raschultz1/IMG_0048_zps1a3ecc39.png http://i48.photobucket.com/albums/f244/raschultz1/IMG_0050_zps78cd3e79.jpg http://i48.photobucket.com/albums/f244/raschultz1/IMG_0049_zpse15ea67d.jpg http://i48.photobucket.com/albums/f244/raschultz1/IMG_0046_zps4e65a21e.jpg http://i48.photobucket.com/albums/f244/raschultz1/IMG_0045_zpsd862a505.jpg
  • 12-02-2014 10:10 PM In reply to
    • trex021
    • Joined on 01-11-2013
    • Minneapolis
    • Posts 269
    Here you go, Rick.  Looks great!
