Best way to integrate Di2 junction box
Last post 06-06-2015 12:31 PM by Taffy. 30 replies.
Page 1 of 3 (31 items) 1 2 3 Next >
  • 01-17-2015 11:42 PM
    So I have seen some pictures of upcoming stems that should have a hideaway area for the front junction box. 3T Integra Team has this already. I have also heard of other guys who hide the front junction box (3 or 5 port) somewhere in the frame and then run the wires as needed. Those of you running Di2, have any of you tried to clean up the front end to make it look cleaner? Or just leave the front junction box hanging down from your stem?
  • 01-19-2015 11:25 AM In reply to
    Re: Best way to integrate Di2 junction box
    I have been relocating front junction box down by front derailleur.It's tucked behind water bottle and you can still trim while riding. You need to run two long (1400mm) cables one to each shifter. It's real easy to clean up front end dealing with wires only and no box.
  • 01-19-2015 11:19 PM In reply to
    Vjl594:
    Do you have a picture of your setup that you would be able to share? Do you just use double sided tape to secure it?
  • 01-20-2015 10:49 AM In reply to
    Don't have any pics now but basically I fabricate a small aluminum bracket that's mounts to lower water bottle bolt.Junction box wire ties to that so nothing in on frame.It can be real small and on most frames that will put junction box between front derailleur and water bottle cage.You can also wire one shifter directly through the handle bar straight to the other shifter then you will only have one wire going to junction box.
  • 01-21-2015 9:43 PM In reply to
    • levi
    • Joined on 08-27-2010
    • Posts 373
    Check out my setup with BarFly 2.
  • 01-21-2015 9:45 PM In reply to
    • levi
    • Posts 373
    Finally with Garmin 510.
  • 01-23-2015 2:40 PM In reply to
    I have under mi 3T integra put some dubble sided tabe. I did not liked to have the rubber kind of strep at the top site of my stem.
    With Kind Regards,
    Stefan
    Cervelo S3 Disk Di2 2017 Size 61
    Cervelo S3 Di2 2014. Size 61
    Aero Rotor Q-Rings
    ENVE 3.4 SES wheels
    ENVE stem, ENVE botles holders
    Rotor Power meter LS
    Shimano Di2 internal battery BT-DN110
    Shimano Ultegra RD-6870 (GS)
    Shimano Ultegra 11-32T
    Shimano Di2 SM-EW101
    Garmin Edge 1000.
  • 02-16-2015 3:30 PM In reply to
    • Toto
    • Joined on 02-11-2015
    • London
    • Posts 7
    Looks really neat. How doe the box secure to the underside??
    2013 Lynskey Cooper CX
    2014 R5 DI2 Enve 4.5's
    Overdraft.....
  • 02-16-2015 4:36 PM In reply to
    I used for mine double sided tape
    With Kind Regards,
    Stefan
    Aero Rotor Q-Rings
    ENVE 3.4 SES wheels
    Garmin Edge 1000.
  • 02-19-2015 10:59 PM In reply to
    • Rick
    • Joined on 07-24-2011
    • SoCal
    • Posts 241
    LEVI - One of the cleanest setups I have seen!
    Now where do you mount the EWW01?
    2011 Cervelo R5ca (56cm): Shimano 6870 Di2/9000 Di2/EWW01 Wireless, Rotor Q-Rings, Dura Ace 9000 C-24.
    2010 Giant TCR Advanced SL Pro (M/L): Shimano 9000 Dura Ace, Shimano Dura Ace 9000 C-35 Wheels.
    2018 Trek Madone 9.4 (56cm): Shimano Dura Ace 9000.
  • 02-26-2015 1:21 PM In reply to
    • Sorvoll
    • Joined on 10-20-2012
    • Norway
    • Posts 3
    If you use a PRO Tharsis stem (designed for Shimano XTR Di2) is it possible to put the junction box inside the stem. PRO Tharsis works great on a road bike even if it is designed for off-road. It is also possible to buy a Garmin/Di2 mount; http://www.racewaredirect.co/shop/garmin-edge-bar-mount-di2-clip/
  • 03-03-2015 11:47 PM In reply to
    • levi
    • Posts 373
    Rick:
     @Rick, looks like I missed this.  To answer your question, I glued it underneath the chainstay.
  • 03-04-2015 1:57 AM In reply to
    Why not inside the frame. I don't want to see the device. It does not mather where it is located.
    With Kind Regards,
    Stefan
    Aero Rotor Q-Rings
    ENVE 3.4 SES wheels
    Garmin Edge 1000.
  • 03-04-2015 7:12 AM In reply to
    • levi
    • Posts 373
    Stefan van Kasteren:
    Inside the frame would be the best location to put everything in. Unfortunately, that would void warranty if you drill holes on my 2012 R5.
  • 03-04-2015 11:15 AM In reply to
    Wait, no drilling of hols, just from the top slide it in. I have put it between my internal battery and the lower junction box next to breaket. I just slided it in from the seat tube. Will this work for you to or do you have an external batery so you cannot get it inside?
    With Kind Regards,
    Stefan
    Aero Rotor Q-Rings
    ENVE 3.4 SES wheels
    Garmin Edge 1000.
