SRAM red etap blanking grommets s3
Last post 04-10-2018 7:38 PM by maustin. 13 replies.
Page 1 of 1 (14 items)
  • 11-14-2016 6:06 AM
    Looking to fit etap but unable to find any grommets to blank holes ....any ideas
  • 11-14-2016 9:45 AM In reply to
    • Posts 423
    Re: SRAM red etap blanking grommets s3
    Ask a Cervelo dealer. The Di2 grommets should be good enough.
  • 11-14-2016 9:52 AM In reply to
    They still have holes in etap is wireless
  • 11-14-2016 10:20 AM In reply to
    • Posts 423
    Now that Cervelo has eTap bikes (S3 disc), try asking them.
  • 11-14-2016 4:04 PM In reply to
    • Posts 964
    Black sugru is your friend. sugru.com
    2015 COR
  • 11-20-2016 2:45 AM In reply to
    Sugru indeed. Apart cables holes I also covered unused bottle cages inserts. The good thing about sugru is when set it's like a rubber. You can unplug whatever you covered and reuse it.
  • 11-20-2016 11:37 AM In reply to
    • Arne
    • Joined on 11-07-2009
    • Montreal, Quebec
    • Posts 92
    Is there any chance that this product will react negatively with the paint finish? Would hate to put on this mouldable "glue" and then have the top tube get ruined by this. The web site says to remove it, you need to scrape off part of it with a knife...
    2016 S2 etap
    2013 R3 red
    2011 S3 DA7900
    2010 P2 DA7900 mix
    2008 Rancilio Silvia & Rocky
  • 11-21-2016 1:53 AM In reply to
    Haven't noticed anything worrying. It doesn't go into any reaction with the paint, at least according to my eyes :)
  • 11-27-2016 10:25 PM In reply to
    • maustin
    • Joined on 04-06-2010
    • Hobart, TAS
    • Posts 44
    What cranks are you fitting? I've just bought a near new 2016 S3 frameset and wanted to swap the eTap off my R3 onto it. Running the RED GXP cranks on the R3, and am trying to ascertain how easy (or not) it is to fit these onto the S3
    That's what you get when you suffer - you get results
  • 11-28-2016 1:43 AM In reply to
    If the cranks are bb30 they won't fit!!!,you can fit gxp cranks with adaptors but I run rotor cranks.i have it all working good but the low stop is wound all the way out.i think the issues lie with aero fame and how close it is ...basically the chain line but I got it to work ok,I do believe if the crank was spaced out 1mm it would allow for a larger range of adjustment,I will try it long term and may swap to sram if it gives me hassle .
  • 11-28-2016 3:02 AM In reply to
    • maustin
    • Hobart, TAS
    • Posts 44
    Yeah, I've got the GXP crankset. Think Wheels Mfg and Enduro both do the appropriate adaptor. This gives a pretty good run down of what's involved: http://blog.artscyclery.com/ask-a-mechanic/ask-a-mechanic-adapting-sram-gxp-to-pf30-bb30-bbright/
  • 11-28-2016 4:02 AM In reply to
    Yes you should be fine then mate ....let me know how you get on and what the shifting is like wen you set it up as I too may go down this route ???
  • 11-29-2016 1:20 AM In reply to
    I'm still getting the chain drop on the top of the teeth on the small front if I'm not far enough up rear cassete,sram recommend 25 mm from bike centreline to bolt center on front mech.i think this is down to frame design .i will be intrested to see how you get on with red crank.thought of spacing crank out 1mm as this will give the mech more inward throw.
  • 04-10-2018 7:38 PM In reply to
    • maustin
    • Hobart, TAS
    • Posts 44
    OK, have been running this set up for about 12 months now. No issues. I've got SRAM Red GXP 52/36 cranks with a BBInfinite BB setup. Was easy enough to fit myself (although getting the old PF BB out was a bit unattractive without the right tools) I do notice I get a bit of chain rub on the large chainring when I'm in my 36 (front) and 11 (rear) - so cross-chaining it full throttle. The rub is not on the FD cage, but actually on the large chainring, so nothing I can adjust out. But I don't cross-chain it normally, so not fussed about that Cheers, Mike
