Di2 on an S3
Last post 12-21-2017 10:55 AM by \\\wes. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • 11-18-2017 11:55 AM In reply to
    Re: Di2 on an S3
    I would love to see photos of that. How does one connect the wire, and get it out if needed?
  • 11-20-2017 5:14 PM In reply to
    Re: Di2 on an S3
    I have Cervelo S3 2015 Di2 and build battery in the seat tube. So have wraped it into innertube to avoid noice and the wire goes to bottom breaket junction box. I also have the new S3 Di2 disk 2017 and this one comes already with build in battery. The battery is in the downtube with an adapter. Note, this adapter does not fit in the old 2015 model. For both (new and old model) you need to have the internal battery. The external is useless!
    With Kind Regards,
    Stefan
    Cervelo S3 Disk Di2 2017 Size 61
    Cervelo S3 Di2 2014. Size 61
    Aero Rotor Q-Rings
    ENVE 3.4 SES wheels
    ENVE stem, ENVE botles holders
    Rotor Power meter LS
    Shimano Di2 internal battery BT-DN110
    Shimano Ultegra RD-6870 (GS)
    Shimano Ultegra 11-32T
    Shimano Di2 SM-EW101
    Garmin Edge 1000.
  • 11-29-2017 3:54 AM In reply to
    Re: Di2 on an S3
    Never tried 2 of them but I heard from my friends that S3 is super strong.
  • 12-21-2017 10:28 AM In reply to
    Re: Di2 on an S3
    Same here on the 2017 version, used sticky backed foam on the battery to stop noises. I also glued on some string in case I need to retrieve the battery in the future. I found it an easy build although some online hints/tips suggested removing the crankset first. This is a waste of time as all the wiring can be done from below the BB with a bit of patients and some spare brake cables. One last point, the frame clips are a little small for Di2 cables so they need to be eased with a 3mm drill bit. Just a shame Cervelo don’t seems to consider this possible 🙁
  • 12-21-2017 10:55 AM In reply to
    Re: Di2 on an S3
    Are you referring to the cable entry grommets? There are Di2 specific grommets that should have been included with the bike I believe.
