Smart trainers (not Wahoo KICKR) compatible with R5 Disc
Last post 06-27-2019 8:08 AM by Remy. 2 replies.
  • 02-10-2018 11:26 PM
    Are there any smart trainers that have adapters that will work with the R5 disc’s proprietary thru axle? I’m currently using the Wahoo KICKR with their 12x142 thru axle adapter which works, but just wondering if there are any other trainers out there that offer thru axle adapters that will work. Thanks again.
    2017 R5 Disc
  • 02-11-2018 5:09 AM In reply to
    • Xriss
    • Joined on 09-02-2017
    • Zurich, Switzerland
    • Posts 17
    Re: Smart trainers (not Wahoo KICKR) compatible with R5 Disc
    I use my R5 disc on a Tacx Neo. you can basically use it on every trainer, which is offering a standard 12 x 142 TA adapter. The only thing you will need to do is to replace your rear derailleur hanger and axle with the ones from a C5. They have the exact same dimensions just with a normal thread instead of RAT.
  • 06-27-2019 8:08 AM In reply to
    • Remy
    • Joined on 06-20-2018
    • Posts 3
     Hi ... you are using the Wahoo thru axle adapter and screw in end cap over the RAT end cap?  Thanks.
