2014 S3 and SP17 seat post
Last post 02-13-2018 9:48 AM by jakes. 3 replies.
  • 02-12-2018 2:57 AM
    • john_nz
    • Joined on 05-15-2014
    • NZ
    • Posts 3
    Hi
    I have a 2014 S3 and I have play in the clamp which results in the seat changing position while riding. Looking at the SP17 seat post as a replacement. Is this compatible with a 2014 S3. Cervelo says that "Compatible with all current Cervélo S series frames." A 2014 frame  is not what I would consider current. Can't seem to find anything definitive.
    Cheers
    Cervelo S3 2014
  • 02-12-2018 10:11 AM In reply to
    • jakes
    • Joined on 03-05-2014
    • Posts 51
    Re: 2014 S3 and SP17 seat post
    Hi john_nz, The SP17 seat post will work with all current version S2, S3 and S5 frames. We have not changed the S3 frame design since 2013, only paint and specs have changed. Hope that helps.
    Jakub Macel
    Cervelo
  • 02-12-2018 5:23 PM In reply to
    • john_nz
    • NZ
    • Posts 3
    Hi Jake, Thanks for the reply. The SP17 with 25mm offset will match the original setup yes? Thanks
    Cervelo S3 2014
  • 02-13-2018 9:48 AM In reply to
    • jakes
    • Posts 51
    Hi john_nz That is correct, both seatposts have a 25mm offset. Cheers,
    Jakub Macel
    Cervelo
