2018 R3 seatpost slipping
Last post 06-20-2018 2:36 PM by Allanj. 10 replies.
Page 1 of 1 (11 items)
  • 04-16-2018 10:42 AM
    • Allanj
    • Joined on 12-24-2014
    • Edinburgh, Scotland
    • Posts 58
    Hi folks. My new R3 is back at the LBS after just a handful of rides as the seatpost is slipping. It drops 20-30mm over a few kms. It's a lovely bike but it is driving me mad! I've cleaned and repasted that post, torqued it up nicely but no luck. I never had any such issues with my R2s, anyone had the same with the new R3? Allan
  • 04-17-2018 8:49 AM In reply to
    • Xriss
    • Joined on 09-02-2017
    • Zurich, Switzerland
    • Posts 11
    Re: 2018 R3 seatpost slipping
    I do not have an R3 but I had a similar issue on one of my MTBs. Check the screw of your seatpost clamp for any dirt or any scratches in its thread which could result in resistance. In my case the resistance in the seatclamp screw was strong enough to make the torque meter click even though the clamping force wasn't nearly high enough to hold the seatpost in place when I put my weight on it.
  • 04-17-2018 8:55 AM In reply to
    • Allanj
    • Posts 58
    Thanks, it is looking more complicated than that, we are waiting for a warranty claim to go through
  • 04-28-2018 9:20 AM In reply to
    • PeteC
    • Joined on 11-13-2017
    • North Vancouver
    • Posts 2
    Hi there, I had the same problem with my R3. I took it to the dealer and they put some friction paste on the tube and it is no longer an issue
    For the hills, Im a savage.
  • 05-25-2018 5:20 AM In reply to
    • Allanj
    • Posts 58
    Lots (and lots) of grip paste and some fiddling at the LBS and it is holding fast so far. Fingers crossed
  • 05-28-2018 5:50 AM In reply to
    i wouldn't be happy with that as my longterm solution
  • 05-28-2018 2:02 PM In reply to
    • PeteC
    • North Vancouver
    • Posts 2
    HarryVolmer:
    Definitely wouldn't bee happy with 'fiddling' either. I would make sure that they are tightening to spec and that they are using the correct paste. Mine was 100% within the first application of the paste and tightening.
  • 05-30-2018 4:48 AM In reply to
    • Allanj
    • Posts 58
    I am not entirely happy either but am keeping an eye on things. No issues for over a month now, and I know I will have good support from my LBS if it recurs
  • 06-05-2018 10:26 AM In reply to
    • trex021
    • Joined on 01-11-2013
    • Minneapolis
    • Posts 269
    The solution is a more aggressive carbon fiber griping paste. There is a difference. Mine slipped badly with the Park Tool paste even when over torqued. I highly recommend you buy a tube of Finish Line Fiber Grip and be done with seat post slippage forever. I use 3nm torque on my R3 seat post clamp.
  • 06-05-2018 11:59 PM In reply to
    • apwndwest
    • Joined on 09-11-2014
    • Vancouver, British Columbia
    • Posts 271
    Bottom line it shouldn't continue. If it does get a warranty replacement u don't spend that type of money to worry about your seat post slipping
    2014 R3 (Hills bike)
  • 06-20-2018 2:36 PM In reply to
    • Allanj
    • Posts 58
    It remains fine. I am (overly) familiar with the warranty process so won't put up with it if it recurs, that's for sure
