Broken frame (warraty)
Last post 05-09-2018 9:47 PM by goodboyr. 10 replies.
Page 1 of 1 (11 items)
  • 05-07-2018 5:04 AM
    • Iker
    • Joined on 07-12-2017
    • Posts 4
    Hello everybody.
    The other day I was riding my S5, and I started feeling the bike "braking" I thought that it could be the brake pads, I slow down but that was right.
     I saw this:
    https://ibb.co/d7PhZS
    https://ibb.co/hHBkon
    https://ibb.co/no5NZS
    https://ibb.co/dwSEg7
     The seat post was hurting the frame until it broke. I got the bike at the shop, I hope warranty will work.
    Any idea or experience like that??? I need help
  • 05-07-2018 10:42 AM In reply to
    • Posts 964
    Re: Broken frame (warraty)
    Simply put, it's the shops fault. The procedure (in the frame manual) is to chamfer cut the corner of the seatpost bottom once the correct height is determined. As well, carbon paste and proper clamp torque prevent slippage. If this isn't done, then any slippage will cause the corner of the post to wear through the frame. I am also sure you were hearing a lot of creaking noises while this was happening over the course of your riding. Lesson to be learned is if you hear noises like this they should be investigated before the damage is done.
    2015 COR
  • 05-07-2018 10:53 AM In reply to
    • Iker
    • Posts 4
    Thank you for the answer. I swear you that I only eard a crack. At that point I stopped. Sorry because my english
  • 05-07-2018 12:28 PM In reply to
    • Noel
    • Joined on 11-02-2012
    • Vancouver, Canada
    • Posts 259
    Any adjustments/modifications made after getting it out of the shop?
    2013 Cervelo S5 - Shimano Ultegra / Zipp 404
    2009 Cervelo S1 - Shimano Ultegra / Zipp 404
    2009 Cervelo S2 - SRAM Force / SRAM S60
    Santa Cruz VP Free
    Santa Cruz Superlight
    Trek Speed Concept
    Trek Marlin
  • 05-07-2018 12:32 PM In reply to
    • Iker
    • Posts 4
    Noel:
    None. I dont like mechanicals......
    • Iker
    • Posts 4
    Noel:
  • 05-08-2018 11:34 AM In reply to
    I heard this happened before on this forum but I cant remember if Cervelo covered it under warranty. Hopefully your LBS has a good relationship with there rep. But yes your LBS was suppose to cut the post on a angle as the owners manual says.
  • 05-08-2018 4:11 PM In reply to
    • apwndwest
    • Joined on 09-11-2014
    • Vancouver, British Columbia
    • Posts 267
    Goodboyr. I just put a new seat post into my R3. Do I need to cut the bottom in an angle? Is that what's meant by chamfer?
    2014 R3 (Hills bike)
  • 05-08-2018 4:17 PM In reply to
    You don't need to do that on the R3. Only S5
  • 05-08-2018 4:21 PM In reply to
    • apwndwest
    • Posts 267
    Rideurbike:
    Gratzi Rideurbike. I was hoping that was the answer.
  • 05-09-2018 9:47 PM In reply to
    • Posts 964
    Yup. Not applicable to round posts. Only the aero ones.
    2015 COR
