Cervelo 2017 105 build, can I fit a 11-32 cassette?
Last post 05-31-2018 1:42 PM by Stephane. 2 replies.
  • 05-31-2018 1:21 PM
    Hello I have a 2017 Cervelo S2 with a 105 build. It currently has a 11-30 cassette. I upgrade crank to 39/53 standard. Will the stock Shimano 105 rear mechanical derailleur accommodate a 11-32 cassette? Thank you Stephane
  • 05-31-2018 1:32 PM In reply to
    • jakes
    • Joined on 03-05-2014
    • Posts 51
    Re: Cervelo 2017 105 build, can I fit a 11-32 cassette?
    Hi Stephane, You would need to change the rear derailleur to the Long cage "GS" version. The spec derailleur only accommodates up to a 30 tooth cassette. The longer derailleur can accommodate up to a 34 tooth cassette. Hope that helps.
    Jakub Macel
    Cervelo
  • 05-31-2018 1:42 PM In reply to
    Thank you !
