What Max Tire width for R2?
Last post 07-20-2018 3:30 PM by hungryman. 7 replies.
Page 1 of 1 (8 items)
  • 06-21-2018 4:41 PM
    I would like to know if a 28mm tire would fit the 2017 Cervelo R2 (Grey)
  • 06-22-2018 11:08 AM In reply to
    • Joined on 11-24-2014
    • Kansas City, Mo
    • Posts 332
    Re: What Max Tire width for R2?
    It really depends on what tire and what wheel width you are asking about. I have a R2 with HED Jet+ wheels that have a rim ID of 21mm and 25mm Continental 4000 SII that have a 28mm actual width and clear.
    2015 COR participant
    2015 S3 Sram Red 11 Speed
    2015 R2 Sram Red 11 Speed
    2013 P5 Dura Ace Di2 11 Speed
  • 06-22-2018 11:22 AM In reply to
    Thanks for the reply...Im planning to use the 28mm tire also from Continental GP 4000 SII, currently using the Mavic Ksyrium wheels with their tires as well Mavic Yksium tires in 25mm
  • 06-23-2018 6:12 PM In reply to
    • Kansas City, Mo
    • Posts 332
    I am not sure of the internal width of the Mavic's. That makes a BIG difference.
  • 07-20-2018 12:03 PM In reply to
    • Art_Mtl
    • Joined on 04-16-2016
    • Montreal
    • Posts 10
    I tied 28mm gatoskins on my R2 fitted no problem. Plus I got this answer from Cervelo: You can fit 25mm tires on your R2 even with 28mm wide rims. The R2 uses a fork with extra wide clearance and the rear has enough clearance. Enjoy the ride!
  • 07-20-2018 12:46 PM In reply to
    Re: What Max Tire width for R2 (Grey color)?
    I understand the front of the R2 would fit a 28mm tire but my concern is the rear, if it fits a 28mm tire, how about the clearance between the chainstay and the tire is there enough room in between? Thanks for the reply.
  • 07-20-2018 3:10 PM In reply to
    • Art_Mtl
    • Montreal
    • Posts 10
    I did put contis gatorskins 28mm and had no rubbing so you should be ok.
  • 07-20-2018 3:30 PM In reply to
    Sounds good since im planning to install the Conti GP4000II tires, anyway, thank you for your reply.
