Sign in
Join
Forum (forum)
Cervélo (group)
(Entire Site)
Cervélo Home ●
Forum
Cervélo
Forum
140mm rotors on R5 Disc
Last post 09-12-2018 2:31 PM by
Xriss
. 6 replies.
Page 1 of 1 (7 items)
Sort Posts:
Oldest to newest
Newest to oldest
Previous
Next
07-05-2018 6:09 PM
boogermin
Joined on 09-18-2012
New York, NY
Posts
90
Reply
Contact
My R5 currently has 160mm rotors, but I’m considering sizing down to 140mm. Would it simply be a matter of removing the caliper adapters front and rear? Does the front caliper require an adapter, even for 140mm? Thanks again, forum.
2017 R5 Disc
07-05-2018 7:57 PM
In reply to
Kookie
Joined on 02-04-2012
Toronto
Posts
432
Re: 140mm rotors on R5 Disc
Reply
Contact
Not 100% sure but I think you just have to flip over the mount-adapter and re-install the calipers. You should see an arrow pointing one way for 160mm and flip it the other way for 140mm.
07-06-2018 8:30 AM
In reply to
jakes
Joined on 03-05-2014
Posts
52
Reply
Contact
That's correct. Flip the adapter so it positions the mounting holes for the caliper lower on the fork and rearward on the chainstay. The adapters are marked so it should be pretty straightforward.
Jakub Macel
Cervelo
08-22-2018 7:26 AM
In reply to
Remy
Joined on 06-20-2018
Posts
2
Reply
Contact
hello ... are you going to 140mm in front and rear wheel? ... or just rear? thx.
09-11-2018 6:53 PM
In reply to
boogermin
New York, NY
Posts
90
Reply
Contact
I was thinking both front and rear.
2017 R5 Disc
09-12-2018 12:09 AM
In reply to
morningsun
Joined on 07-05-2017
Posts
1
Reply
Contact
Assuming the R5 and S3D has the same mount, I can't figure out the rear. The adapter is longer than the caliper and if I turn it around, the screw holes doesn't much up.
09-12-2018 2:31 PM
In reply to
Xriss
Joined on 09-02-2017
Zurich, Switzerland
Posts
11
Reply
Contact
Only front adapters have to be turned if going from 160mm to 140mm or vice versa. Rear adapter just has to be renoved to go to 140mm from 160mm.
