140mm rotors on R5 Disc
Last post 09-12-2018 2:31 PM by Xriss. 6 replies.
Page 1 of 1 (7 items)
  • 07-05-2018 6:09 PM
    My R5 currently has 160mm rotors, but I’m considering sizing down to 140mm. Would it simply be a matter of removing the caliper adapters front and rear? Does the front caliper require an adapter, even for 140mm? Thanks again, forum.
    2017 R5 Disc
  • 07-05-2018 7:57 PM In reply to
    • Posts 432
    Re: 140mm rotors on R5 Disc
    Not 100% sure but I think you just have to flip over the mount-adapter and re-install the calipers. You should see an arrow pointing one way for 160mm and flip it the other way for 140mm.
  • 07-06-2018 8:30 AM In reply to
    • jakes
    • Joined on 03-05-2014
    • Posts 52
    That's correct. Flip the adapter so it positions the mounting holes for the caliper lower on the fork and rearward on the chainstay. The adapters are marked so it should be pretty straightforward.
    Jakub Macel
    Cervelo
  • 08-22-2018 7:26 AM In reply to
    • Remy
    • Joined on 06-20-2018
    • Posts 2
     hello ... are you going to 140mm in front and rear wheel? ... or just rear? thx.
  • 09-11-2018 6:53 PM In reply to
    I was thinking both front and rear.
    2017 R5 Disc
  • 09-12-2018 12:09 AM In reply to
    Assuming the R5 and S3D has the same mount, I can't figure out the rear. The adapter is longer than the caliper and if I turn it around, the screw holes doesn't much up.
  • 09-12-2018 2:31 PM In reply to
    • Xriss
    • Joined on 09-02-2017
    • Zurich, Switzerland
    • Posts 11
    Only front adapters have to be turned if going from 160mm to 140mm or vice versa. Rear adapter just has to be renoved to go to 140mm from 160mm.
