Garmin mount for Cervelo AB06 bar...
Last post 09-05-2018 1:09 PM by 1UCLAman. 9 replies.
Page 1 of 1 (10 items)
  • 07-17-2018 12:23 AM
    • 1UCLAman
    • Joined on 06-25-2011
    • Pico Rivera, CA
    • Posts 167
    As the subject says which mount are others using with the Cervelo AB06 bar??
    2010 S1 with full SRAM Red gruppo and Williams S38 wheelset. Zipp Service Course SL Stem and Zipp SL Bar, Fizik Antares VS saddle. Zipp bottle cages.
    2018 R5d Classics - full Sram Red mechanical, Mavic pro carbon disc wheels, Cervelo AB06 bars with Cervelo stem. Antares R1 Versus Evo seat
  • 07-17-2018 2:58 PM In reply to
    Re: Garmin mount for Cervelo AB06 bar...
     Options are limited since bar anchored mounts are offset, which is a shame because it is a great bar.  I had been tempted to switch to a different bar/stem combo, but have decided to stay with the AB06.
    I did use the Barfly that is suggested in the owner's manual, but did not love it since it does not allow for a camera mount underneath.  Also, customer service for Barfly is pretty terrible.
    I now use: http://www.racewaredirect.co/shop/carbon-garmin-edge-gopro-light-faceplate-mount/
    Never had any experiences with a 3D printed item, but it seems pretty solid.
  • 07-19-2018 12:02 PM In reply to
    • 1UCLAman
    • Pico Rivera, CA
    • Posts 167
    Thanks NYC, did some more research and found a thread on this site which had asked this question a few months ago - https://forums.cervelo.com/forums/p/16513/110250.aspx as well as other websites. Anyway, decided to go with the Barfly option even though i was able to mount the original Garmin mount on the AB06 bar although it's not perfectly straight and that bugs me. Since I dont plan on mounting a light or gopro, the Barfly option should be fine. My other bike will get the original Garmin mount back soon.
  • 07-25-2018 9:53 AM In reply to
    NYCPrynne, what dimension did you get for the Raceware mount? Measuring the bottom bolts, they look to be 18mm apart which is not an option on the ordering page. Thanks.
  • 07-25-2018 11:06 AM In reply to
     For the AB06 bar and stem on the R5d, it was 28 mm.  Fits perfectly.
  • 07-25-2018 1:58 PM In reply to
    Thanks!
  • 09-03-2018 3:08 PM In reply to
    • Posts 436
    Found this one (expensive): https://www.f3cycling.com/formmount
  • 09-04-2018 10:58 AM In reply to
    I had this one first and it was not great. Almost impossible to get straight as you tighten the bolts since they are independent.
  • 09-04-2018 11:02 AM In reply to
    • Posts 436
    normcorriveau:
    Yes, I read the reviews about how difficult it is to tighten...I am waiting for the Barfly for my AB06 from my LBS.
  • 09-05-2018 1:09 PM In reply to
    • 1UCLAman
    • Pico Rivera, CA
    • Posts 167
    You will not regret the Barfly! Love mine!!!
