2015 S3 - Ultegra 6770 Di2 upgrade/cable options
Last post 11-27-2018 9:35 AM by \\\wes. 3 replies.
  • 11-19-2018 3:36 PM
    Hi all I am looking to tidy up the front end of my cockpit as the junction box of the 6770 Di2 system looks a bit messy dangling down with the other cables. I have the stock 3T ergonova pro bars still. Does anyone have any tips on cable management/tidying or have done it already? Failing that, what would I need to be able to use the handlebar plug junction box or even the older stem mounted junction box? Still love this amazing bike :) cheers TJ
  • 11-23-2018 6:21 PM In reply to
    Re: 2015 S3 - Ultegra 6770 Di2 upgrade/cable options
    My winter project is to do the same tidying of the DI2 cables. I will be using the bar end connector/junction box. I also have the wireless box for connection to Garmin. My plan is to drill two small holes in the drops near to the end to take the cables and then everything else passed through the bars. The only cable from the frame will the shrink wrapped to the front brake cable. In theory only two cables on show which at least be be as clean as a Etap
  • 11-24-2018 2:44 PM In reply to
    Ah nice. What Di2 do you have at the moment? Be great to see some before and after photos !
  • 11-27-2018 9:35 AM In reply to
    Agreed, I am in the same boat and would love to see some photos of your process and results. Do you have the external battery, and if so are you converting to an internal one?
