2012 S2 with Pro-Lite Bracciano wheels and 25mm tyres - any tyre clearance issue?
Last post 03-23-2019 9:21 PM by Debash. 2 replies.
  • 03-23-2019 6:22 AM
    Hi all I’m currently using American Classic 420 Aero3 wheelset with Conti GP4000 SII 23mm tyres, and the tyre clerance is very tight. I’m looking to buy Pro-Lite Bracciano Caliente 45mm carbon wheelset along with Michelin Power Competition 25mm tyres. The rim widths of Bracciano Caliente is stated to be 15mm inner and 22mm outer, whilst Michelin 25mm tyres with stated pressure measures ~28mm. Just wanted to check if anyone here has tried the combination of 2012 S2 with Caliente 45mm deep wheels with Michelin Power Competition 25mm tyres and if there is likely to be any issue with either front or rear tyre clearance (28mm actual tyre width when inflated) as well as with calliper brakes. Thanks in advance. Cheers
  • 03-23-2019 5:45 PM In reply to
    • m66
    • Joined on 05-29-2014
    • Posts 37
    Re: 2012 S2 with Pro-Lite Bracciano wheels and 25mm tyres - any tyre clearance issue?
    Hmmm....while I can't speak to how much clearance a 2012 S2 has, I can tell you that I run 25mm Mich Power Comps on November Rail 52s. They measure 24.5mm at 80psi. The rims are 18mm inner, 25.1mm at the brake track, and 27mm at their widest point. On your rims, these tires should be narrower.
  • 03-23-2019 9:21 PM In reply to
    Thanks, that’s helpful!
