Cervelo s5 VWD rear brake
Last post 04-02-2019 3:08 PM by Kookie. 1 replies.
Page 1 of 1 (2 items)
  • 04-02-2019 11:48 AM
    Hi any help would be appreciated. I’m not the most mechanically gifted of people! I have a 2014 S5 VWD and the run SRAM force brakes. I have removed the rear brake to tighten it and an struggling to re attach the brake to the frame via the brake plate because due to the shape of the SRAM calliper I can’t get the Alan key into tighten the bolt up. Any tips would be appreciated!! Thanks in advance!
  • 04-02-2019 3:08 PM In reply to
    • Posts 436
    Re: Cervelo s5 VWD rear brake
    If it's the problem I am thinking of, try using need nose pliers or an "Ball Hex" Allen key (I think Park Tool have one on one end). Or try a different bolt so you can use pliers.
