"S-Series" vs S3
Last post 02-07-2020 2:32 PM by Don. 10 replies.
Page 1 of 1 (11 items)
  • 07-21-2019 12:18 PM
    • m66
    • Joined on 05-29-2014
    • Posts 39
    "S-Series" vs S3
    Has any info been posted about the S-Series bike on the Cervelo website? It appears to be the same as the new S3, but the frame price is $4000 vs $4200 for the S3 frame.
  • 07-25-2019 10:48 PM In reply to
    • Art_Mtl
    • Joined on 04-16-2016
    • Montreal
    • Posts 26
    Re: "S-Series" vs S3
    maybe it's like the new S2 since there's no more S2.
  • 07-29-2019 10:15 AM In reply to
    I don't see an R2 either. Maybe they'll come out with an R-Series?
    2016 R3 Ultegra Di2 61cm
  • 08-02-2019 5:52 PM In reply to
    the interesting part is when you look at the frame only price (disc option) the S3 is $200 more than the S-Series.... and specs are the same so does that mean the S3 is a lighter layup? I know at one time the difference between one model number and another was the weight when they came out of the mold, but in some cases the layup was different so I don't see what the difference is... and they don't set up the full builds to make it look like the S3 is the premium frame? the S- Series is disc only while S3 is both options but the disc frame S3 is $200 more than the Series frame only?
  • 08-06-2019 11:43 AM In reply to
    • m66
    • Posts 39
    There was a time when this forum was monitored by Cervelo employees and questions like this would get answered....I asked my local dealer and they didn't know, said they would check with Cervelo but I haven't heard back from them yet. Interestingly, when the new (2019) S3 and S5 were launched, the "S-Series" moniker was attached to all of them - it was written on the top tube and also on the seat tube. This year, it still appears on the S3, BUT NOT ON THE S-SERIES! It doesn't show on any of the S5 frames except the Sunweb team frameset. Reason I'm asking is I'm considering buying an S3 disc frame only - color way on the S-Series disc frame only is black/red, which I like. Color way on the S3 disc frame only is yellow, which I don't want. But I really want to know why the S-Series is $200 less. It used to be S5 hi mod, S3 standard mod. Is there an even lower (heavier) mod for the S-Series?
  • 08-06-2019 6:23 PM In reply to
    Actually I was lucky enough to be at a Cervelo talk with one of the composite engineers. There has never truly been a hi mod lo modulus Cervelo, as he put it the right modulus for the situation. So that is just a marketing thing and not an engineering thing. Carbon lay up is a very complicated business and they have special programs to decide what modulus goes where and how much, what orientation etc. So I doubt for $200 that is the difference. I wish I knew though because it is weird. For instance the S5 was a whole different bike and they had a VWD version which used a bit nicer lay up, resin application, and was a bit lighter. It was no hi modulus, the only way to tell the two apart was by the weight of the frame. The difference was about 200g or so as I recall.
  • 08-07-2019 5:35 AM In reply to
    • Xriss
    • Joined on 09-02-2017
    • Zurich, Switzerland
    • Posts 17
    It looks like the S-Series is Etap only. Therefore no routing for shifting/Di2 cables and no Di2 Battery fixation which might be the reason for the lower frame price.
  • 01-17-2020 5:13 PM In reply to
    • Joined on 11-24-2014
    • Kansas City, Mo
    • Posts 355
    I still wish I could get an answer on this!
    2015 COR participant
    2015 S3 Sram Red 11 Speed
    2015 R2 Sram Red 11 Speed
    2013 P5 Dura Ace Di2 11 Speed
  • 01-17-2020 10:07 PM In reply to
    From what I've been told is that its just going to be the new name of the S3. After they have cycled through the current S3s that will be the new name for that series. It will be S5 and S.
  • 01-17-2020 10:22 PM In reply to
    • Kansas City, Mo
    • Posts 355
    So why is there 200.00 diference between the frames... If they are the same?
  • 02-07-2020 2:32 PM In reply to
    • Kansas City, Mo
    • Posts 355
    It turns out it is a misprint. They are the same. I have to thank Cervelo for reaching out to me! Thanks!
