Help Needed 2013 S2 owners (wheelset question)
Last post 09-16-2019 7:19 PM by Don. 6 replies.
Page 1 of 1 (7 items)
  • 09-12-2019 4:40 PM
    Hello I have the blue & Black 2013 S2, but i wanted to upgrade to a HED 5 plus 25mm external width carbon rims. The Specs on the old s2 says only 23mm wheels , do any of you tried a 25mm rims and tires or a 25mm rims w/ 23mm gatorskins on yours ? Any help is gladly appreciated ! Thank you so much in Advance! JT
  • 09-16-2019 10:02 AM In reply to
    Re: Help Needed 2013 S2 owners (wheelset question)
    This one, correct? https://bikerumor-wpengine.netdna-ssl.com/wp-content/uploads/2013/11/S2-3-4-105-600x300.jpg I have a 2015 S3 with 28mm external carbon rims and 25mm Continental GP5000 clinchers (not tubelss) with no issues at all. I previously had 25mm Continental GP Forces on the same wheels, and the rear would rub occasionally on the seat stays. The fork on the S2 is different so I can't comment directly, but I have zero issues on the front. Thanks, -Wes
  • 09-16-2019 10:04 AM In reply to
    This one, right?
  • 09-16-2019 12:53 PM In reply to
    Cheers from sandiego \\\wes !!! Thank you so much for your time ! Yess thats my S2 ♥! Ive been wanting to buy this $799 hed 5 mm wheelset , but my worries are - its 25mm and my specs wheelset is 23mm.. Thank you so much for your Thoughts and Recommendations! JJ
  • 09-16-2019 12:55 PM In reply to
    I think the Front wld be alright - the rear is the problem - maybe ?
  • 09-16-2019 1:26 PM In reply to
    For reference, here is the rim that I am using. It looks like the HEDs are 21mm internal, which will make a give section width tire wider than my 19.5mm internal rims.
    I don't know the actual section widths on Gatorskins, but you might be OK/might not. A 23mm tire seems awfully narrow going onto a 21mm internal width rim.
  • 09-16-2019 7:19 PM In reply to
    • Joined on 11-24-2014
    • Kansas City, Mo
    • Posts 346
    It really depends on what tires you use. Continental 4000 S 2 has a section width of 25mm on the HED wheels. On my S3 that is what I ran. Continental 25mm tires rubed the chain stay. They measured about 28mm. I can measure them tomorrow. I have a S2 build that I am doing right now with HED's on it. I will post some pictures tomorrow.
    2015 COR participant
    2015 S3 Sram Red 11 Speed
    2015 R2 Sram Red 11 Speed
    2013 P5 Dura Ace Di2 11 Speed
