Help Needed 2013 S2 owners (wheelset question)
Last post 09-19-2019 3:08 PM by creepy_maverick. 15 replies.
  • 09-12-2019 4:40 PM
    Hello I have the blue & Black 2013 S2, but i wanted to upgrade to a HED 5 plus 25mm external width carbon rims. The Specs on the old s2 says only 23mm wheels , do any of you tried a 25mm rims and tires or a 25mm rims w/ 23mm gatorskins on yours ? Any help is gladly appreciated ! Thank you so much in Advance! JT
  • 09-16-2019 10:02 AM In reply to
    Re: Help Needed 2013 S2 owners (wheelset question)
    This one, correct? https://bikerumor-wpengine.netdna-ssl.com/wp-content/uploads/2013/11/S2-3-4-105-600x300.jpg I have a 2015 S3 with 28mm external carbon rims and 25mm Continental GP5000 clinchers (not tubelss) with no issues at all. I previously had 25mm Continental GP Forces on the same wheels, and the rear would rub occasionally on the seat stays. The fork on the S2 is different so I can't comment directly, but I have zero issues on the front. Thanks, -Wes
  • 09-16-2019 10:04 AM In reply to
    This one, right?
  • 09-16-2019 12:53 PM In reply to
    Cheers from sandiego \\\wes !!! Thank you so much for your time ! Yess thats my S2 ♥! Ive been wanting to buy this $799 hed 5 mm wheelset , but my worries are - its 25mm and my specs wheelset is 23mm.. Thank you so much for your Thoughts and Recommendations! JJ
  • 09-16-2019 12:55 PM In reply to
    I think the Front wld be alright - the rear is the problem - maybe ?
  • 09-16-2019 1:26 PM In reply to
    For reference, here is the rim that I am using. It looks like the HEDs are 21mm internal, which will make a give section width tire wider than my 19.5mm internal rims.
    I don't know the actual section widths on Gatorskins, but you might be OK/might not. A 23mm tire seems awfully narrow going onto a 21mm internal width rim.
  • 09-16-2019 7:19 PM In reply to
    • Joined on 11-24-2014
    • Kansas City, Mo
    • Posts 355
    It really depends on what tires you use. Continental 4000 S 2 has a section width of 25mm on the HED wheels. On my S3 that is what I ran. Continental 25mm tires rubed the chain stay. They measured about 28mm. I can measure them tomorrow. I have a S2 build that I am doing right now with HED's on it. I will post some pictures tomorrow.
    2015 COR participant
    2015 S3 Sram Red 11 Speed
    2015 R2 Sram Red 11 Speed
    2013 P5 Dura Ace Di2 11 Speed
  • 09-19-2019 11:12 AM In reply to
    Thank you so much for the Insight Guys ! I saw this $799 deal 56mm hed rims @ #mybikeshop.com thats why , i thought id get myself a great deal! ill check my local bike shop if they can put a test rear wheel with 25mm width carbon rims - to see the actual clearance. Thank you so much Guys I aapreciate your time! @Don @\\\wes ☺
  • 09-19-2019 11:23 AM In reply to
    A fit test is a great idea, but do note that it's not the external width of the wheel that could be an issue - its the combination of the internal width (21mm in the case of HED Jet 5) and the section width of the particular tire that you plan to run. Higher internal width with cause a tire in a given section width to run wider, and that is what will possibly rub on the chain stay. Just make sure that whatever wheel-tire combo that your LBS is able to provide matches the internal width, and ideally the actual tire make/model that you intend to run.
  • 09-19-2019 11:48 AM In reply to
    • Kansas City, Mo
    • Posts 355
    Here is the S2 I am building right now. This one has HED Jet 4+ in the front and Jet 6+ in the rear with 25mm Continental 5000 with I also run on my S3. They clear fine. The older GP 4000 tires were bigger and the widest I can run with them is 23mm. (that is what is in the pic of my S3)
    IMG_0463
    IMG_4033
  • 09-19-2019 1:42 PM In reply to
    Thank you \\\wes !! We discussed abt using 23mm gatorskin and 25mm carbon rims next week
  • 09-19-2019 1:43 PM In reply to
    they are gorgeous ! yes I have the same s2 and they are sturdy
  • 09-19-2019 1:59 PM In reply to
    • Kansas City, Mo
    • Posts 355
    Thanks! I am not sure how the gator skins fit. Make sure the carbon wheels have a 21mm ID if you are comparing to the HED's Are the roads in your area terrible? I even have 5000's on my tandem. This is France with the Mediterranean Sea in the background. I am kind of a HED guy! Get a hold of me with any questions.
    IMG_0303
  • 09-19-2019 2:24 PM In reply to
    Very Nice Don!!!
  • 09-19-2019 2:29 PM In reply to
    the 23mm hard shell gatorskins complement my commuting and training regimen - although san diego ca roads are worst in terms of debris on the bike lanes . pls let me know if your S2 project rolls out flawlessly with the hed 25mm - ive been looking at other sources since my budget is only $799. my chinese knockoffs (baixiang ( at 4 yrs old ) are beginning to fail and better be safe than sorry in the next few weeks
