Hex wrench recommendation wanted
Last post 11-09-2019 10:54 AM by Lloyd Deane. 2 replies.
  • 11-07-2019 1:27 PM
    Hi all, I was tired of using ill-fitting hex wrenches and recently bought an expensive set of Wera Hex-Plus. I was disappointed to discover that they too don't seem to fit very well. The Wera tools along with all the others I've used seem to be too loose fitting. That is, there appears to be too much play in the bolt-tool interface. I'm dealing with what I assume are standard hex bolts (for the bike industry) some of which came with my 2012 Cervélo R5 VWD (e.g., 3T) and others from high profile manufacturers whose parts I used to build the bike (e.g., Ritchey, Easton, Shimano). My questions are: 1) should I expect all hex bolts from the brands noted above to be manufactured to the same spec? 2) should I expect hex keys to fit more snuggly within the bolts, or am I labouring under a false assumption? 3) is there a brand that is known for their good fit (i.e., tighter fit) with 'standard' size bike hex bolts? Thanks in advance for your contributions. Cheers, Lloyd
    Every time I see an adult on a bicycle, I no longer despair for the future of the human race.
    ~H. G. Wells
  • 11-09-2019 9:02 AM In reply to
    • Posts 973
    Re: Hex wrench recommendation wanted
    This review has a table of sizes and it concludes the Bondhus ones are oversized compared to Wera and my favourites the PbSwiss. https://www.bikeradar.com/features/allen-keys-everything-you-need-to-know/
    2015 COR
  • 11-09-2019 10:54 AM In reply to
    Thank you, it's an excellent article. Bondhus seems to be the way to go in terms of specs, quality, and based on additional research, price as well.
    ~H. G. Wells
