2016 Cervelo S2 and Conti GP5000 25mm Tires
Last post 01-17-2020 4:42 PM by Don. 2 replies.
  • 11-30-2019 4:16 PM
    Hi, Does anyone know if there would an issue fitting 25mm tires (specifically the Continental GP5000 clinchers) on a 2016 Cervelo S2 frame? Thanks
  • 12-11-2019 9:41 AM In reply to
    Re: 2016 Cervelo S2 and Conti GP5000 25mm Tires
    I have 25mm GP5000 clinchers on FarSports 19.5mm internal/28mm external width rims on a 2015 S3 (same frame as your S2) with ~2.5mm clearance to the seat stays. The rear wheel has to be centered pretty well, but I have no issues with it. The front has about the same clearance all around. I previously had 25mm GP Force front and rear, and they would rub occasionally on the seat stays. GP5000s are definitely a better fit.
  • 01-17-2020 4:42 PM In reply to
    • Joined on 11-24-2014
    • Kansas City, Mo
    • Posts 355
    I have a 2015 S3 with HED wheels (with 21mm ID rim width) The 25mm GP 5000 clear fine. The GP 4000 tires did not.
    2015 COR participant
    2015 S3 Sram Red 11 Speed
    2015 R2 Sram Red 11 Speed
    2013 P5 Dura Ace Di2 11 Speed
