2016 R2 (Grey/Orange) Max Tire Clearance
Last post 08-02-2020 11:53 AM by hungryman. 6 replies.
Page 1 of 1 (7 items)
  • 04-29-2020 6:00 PM
    I wanted to try a 28C tires on my R2.. will it fit?
  • 05-01-2020 1:08 PM In reply to
    Re: 2016 R2 (Grey/Orange) Max Tire Clearance
    I purchased my R3 in 2016...its the black frame with the white top tube. I don't know if this will help but I've only gone up to 25 on the R3. I don't think I could fit 28s in there.
    2016 R3 Ultegra Di2 61cm
  • 05-01-2020 1:16 PM In reply to
    Thanks for the reply...im currently using 25C tires, im just curious if it fits a 28C before buying a pair, but i guess 25C is max for this year model R2 and maybe that includes the R3 as well.
  • 05-01-2020 1:28 PM In reply to
    I think the R2 has a different fork thank the R3 but it's still pretty tight by the bottom bracket/chainstays.
  • 05-01-2020 1:39 PM In reply to
    The R2s fork has enough clearance for a 28C ,its the rear (chainstay/seat tube)that might not have enough space for a tire wider than 25C in my observation unless i get to try and install one.
  • 08-01-2020 11:45 PM In reply to
    • Art_Mtl
    • Joined on 04-16-2016
    • Montreal
    • Posts 27
    i have 2016 R2 and conti gators 28 fit no problem
  • 08-02-2020 11:53 AM In reply to
    Mine was not a success, i installed a 28C Conti Ultrasport ll on my 15mm ID rim, after like 3-4 rides i noticed it rubbed out the top coat and paint almost exposing the Carbon of the rear NDS seatstay. inflated it at 85psi.
