Possible wrong size
Last post 07-29-2020 7:40 AM by Lincolndave. 14 replies.
Page 1 of 1 (15 items)
  • 05-08-2020 7:11 PM
    Possible wrong size
    I went in to LBS to try a few saddles and while I was on my bike so he look look at my posture he said the geometry of this bike is not right for you. I have a 2014 R5 56cm and got me thinking should I be in a 54? I ma 5’11 with 32’ inseam. I did do a bike fit but it was after I got the bike so now I am wondering if I should move to a smaller frame or a different brand that would have geometry suited to my build and riding style. I am by no means a strong rider, more of a weekend warrior so I am now struggling with the fact maybe this is too much of a bike for me. Anyone else buy a bike only to realize this doesn’t suit my abilities? Obviously bikes have gotten even more technical sine this model so that would be a positive but trying to figure out what this bike is worth and going through the process of selling it would be a headache.
  • 05-11-2020 8:50 PM In reply to
    Re: Possible wrong size
    Without knowing all the details, my initial reaction is you should potentially invest $300 in a new bike fit as opposed to $3000+ on a new bike. Unless you have already cut the steerer tube, the 2014 R5 does allow for quite a bit of adjusting. You can raise/lower your stack, raise/lower seat tube, move saddle front/back, change angle of saddle. You can try an offset/non-offset seatpost, you can experiment with different length and angle stems. A good fitter will test everything, and once you are comfortable with posture, he/she will then try a variety of saddles. I have spent $ twice on professional fittings and both times the results were way more valuable than a new set of wheels or component upgrade. I was with the fitter for 3+ hours each time and we went through a ton of minute tweaks until I felt dialed in. You say you already got fit. Were you happy and comfortable on the bike after that fitting? Also, there's no such thing as too much bike. Riding should make you happy. You have a top-level machine in the R5. Most of us will never be good enough to max out or bike's potential, it doesn't matter.
  • 05-18-2020 6:17 PM In reply to
    • Butch
    • Joined on 07-07-2016
    • Moved from Southern Maine to Florida
    • Posts 63
    I'm 5'9" with a 30" inseam and ride bikes sized from my Cervelo R2 51cm to a Ridley Noah 54cm. I have to say that the Ridley is at the top of the scale size wise for me, but I did get a fitting when I bought it and it has turned out to be nearly as comfortable as my smaller and less aggressive R2. Then again, bike frames from different manufacturers can be quite different even though marked the same size, since there's no standard set for size that I know of. There should be plenty of adjustment in your R5. Saddle positions, Stem length/angle, Drop Bar depth/width. You can even try different length cranks if that might help. Unless it's just a case of a too aggressive (or actually just too large a frame) for the type of riding you do or your flexibility limits, give a good pro fitter a shot at it. If the bike still isn't comfortable for you, then by all means go through the process of selling your R5 and find a bike that fits and makes riding the fun activity it should be. There are so many different geometries out there now, that it's not that hard to find a bike that matches and fits you near perfection. And by the way, unless a cyclist rides professionally or intensely trains all the time, as was said in the post above, most of us will never come close to maxing out the performance capabilities of a good modern bike like your R5.
    Step 3: Complete Ultegra R8000 Groupset installed
    Step 4: Near Super bike status. It's my go to bike for most rides.
  • 05-20-2020 9:26 PM In reply to
    Take your bike to your bike fitter and s/he should be able to make the r5 work or come close to your set up needs, that can be going with a different stem, handlebars, etc. the 2014 r5 will have a higher head tube for more upright riding. Cervelo also has a shorter reach than say trek or specialized so it may work. If you got fitted, you should know your saddle to center stem measurement, handlebar to seat, or other to name a few. Let your fitter tell you it won’t work because of x,y,z. I’ve heard whoppers from several lbs. for example, the s3 was designed in such a manner that it couldn’t shift properly with Q-rings. Funny how another bike store was able to get it to shift just fine, I got fitted at fit Werx and the 300 investment has been well worth it. Enjoy the frame, it’s a good frame and you can get plenty of miles and riding with it. Good luck.
    R5 vwd Sram Force 22
  • 05-21-2020 6:28 PM In reply to
    I appreciate the advice and thoughts and everyone is absolutely correct that as a recreational rider, I will never get the maximum out of this bike. Having said that, since I had the bike fit done after I bought the bike lot can change and has changed in a few years like body composition (polite way of saying weight increase). I have made a appointment with a local physical therapy place that do bike fits and make recommendations on posture and bike bio mechanics. He is very well respected locally and nationally so I am hoping this will certainly help me enjoy the bike a lot more. Some back information on how I got to this point. When I bought the bike I rode a lot, avg 40-50 mile rides 3-4 times a week. However I took a nasty fall coming down a hill when it was wet and I went from a 28-30mph to a dead stop. I cracked my helmet in 2 pieces but bike survived and ever since its been hard to get back on. This winter I kept looking at the bike sitting downstairs in our workout room thinking this bike is way too pretty for it to be collecting dust. I need to get out and ride this thing so that is what I have started to do. I changed the stem and OEM saddle few weeks back but still need to dial it in as I know I can ride more miles but always want to stop around 35 mile mark due to soreness. Also now I am very weary on downhills and start riding the brakes around 22mph which kind of sucks but anything faster and I feel like I am out of control. I am hoping once the bike fit is done I can get my confidence back and control the bike better.
  • 05-23-2020 8:33 AM In reply to
    Good luck with the fit and on descents, I self talk to remind myself to stay relaxed, don’t death grip, and breathe. I’m pretty sure it’s in my head versus something mechanic (except for the time someone forgot to tighten the steerer bolt lol). I actually find it more stable to sit on the top tube then in th saddle for descents. Good luck getting back into things and enjoy the ride.
  • 05-23-2020 9:43 AM In reply to
    I am the same size/inseam as you, same general riding prefs, and bought a NOS 2014 R3 last year @ size 56, had it fitted (albeit not a $300 pro fit, more the "pay and get the bike out the door" version) and other than the normal adjustments all I had to do was swap for a short stem. In fact to fit me the seat is quite high (5" exposed seat tube), and I have several spacers in the stem, like 2' worth, so it's not like my 56 is set to minimums, I think a 54 would be on the small side. IMO at our height/reach either a 54 or 56 can be made to fit. Let me know if you want pics/measurements. Cheers
    Cervelo R3
    Trek Top Fuel 9
  • 06-06-2020 4:49 PM In reply to
    Well I got the bike fit done couple of weeks ago and all I have to say is I feel like a new bike owner again. Some adjustments on pedals, stem, seat post and changing the saddle (Selle Italia Gel Flow Man). I feel like I am in more control of my bike and can ride without getting sore. This week alone I put on 250 miles on the bike and am loving my new old bike, now only if I can get R5 with disc brakes. Here is a pic of my bike looking east from Seattle on the I90 floating bridge. picture upload sites
  • 06-08-2020 3:24 PM In reply to
    Congrats!
    2016 R3 Ultegra Di2 61cm
  • 06-09-2020 2:36 PM In reply to
    Yes - congrats on the results. As someone that has been hit by a car, there is that fear at first, but you should get over it in time. Of course, I do tend to think that a childhood in the 80s sans helmet and zipping in & out of traffic in a busy summer coastal Maine tourist trap also lends itself to not being wary of cars and or having a good understanding of the physics lol. btw, Both of my bad crashes were high speed, the car hit me while I was going downhill approx 35 mph and then hitting the wrong angle on RR tracks doing about 25.
  • 06-09-2020 3:31 PM In reply to
    Ouch. Sounds terrible. When you’re ready, upgrade to etap force or red. You will love it!
  • 06-09-2020 10:06 PM In reply to
    • Butch
    • Posts 63
    Great that a fitting worked out so well for you... and great looking R5. Nothing worse than an ill fitting bike to make riding an unpleasant experience. And it saved you some cash for now, anyway. That Disc R5 will definitely drain away some bucks when it comes time to purchase.
  • 06-10-2020 6:23 AM In reply to
    Excellent news, I am 5-10 inches and have a 56 c3 and a 56s3, both fit me fine
  • 07-20-2020 9:04 PM In reply to
    The new R5 has a lower head tube height so really, you should get an R-Series (R3} which will be closer to your 2014 R5 geometry. I think Cervelo is going disc for all their bikes this year so if you want a rim brake R5 2019 is going to be the last year to get one. I think for recreational riding disc brakes aren't needed. If anything they will be more of a headache having to constantly tinker with them to keep them from making noises.
  • 07-29-2020 7:40 AM In reply to
    To true about the disc brakes, I have them on my c3, I will never buy another bike with disc brakes
