2013 R3 FD bolts
Last post 08-18-2020 3:55 PM by cawright1375. 7 replies.
Page 1 of 1 (8 items)
  • 07-21-2020 12:37 PM
    2013 R3 FD bolts
    Has anyone with a 2013 R3 had any issues with the frame around where the FD bolts are? Specifically the bolt "closest" to the front wheel? I run SRAM Red 22 on it and absolutely no one can get it so the Yaw FD works properly and just last week I noticed that the frame has some weird bubbling/ cracking in the paint and of course I can't tell if it's cosmetic or structural, but every time the FD is adjusted it goes out of adjustment the minute I start using it.
  • 07-21-2020 3:48 PM In reply to
    Re: 2013 R3 FD bolts
    .. has your R3 2013 a socket mount ore is there a clamp for the FD ?? The socket is mounted with rivets and they can be replaced [if the frame has no damage] .. pics ??
  • 07-21-2020 4:55 PM In reply to
    It’s a braze on mount installed by Cervélo. I have a picture but have no clue how to post it here.
  • 07-21-2020 9:02 PM In reply to
    .. search for a bike workshop that can handle the task and renew the rivets for the fd socket after looking at ..
  • 07-23-2020 9:03 AM In reply to
    Yeah, so, apparently it could be the rivets, but how do they "renew" them? That is what I'm wondering after talking with Cervelo yesterday and of course I forgot to ask.
  • 07-23-2020 12:44 PM In reply to
    • Posts 974
    They drill out the old ones and pop in the new ones. Most shops can do this.
    2015 COR
  • 07-28-2020 1:58 PM In reply to
    Thanks, I ended up following up with the Cervelo rep. The bike is at the shop since the weekend and I am just waiting patiently to hear now. Hoping one way or the other my FD issues will be solved after this. Should the frame & bolts be fine, then the culprit could be that I need a SRAM FD shim due to seat tube angles and SRAM Yaw FD technical specis as checked by the SRAM tech support head.
  • 08-18-2020 3:55 PM In reply to
    Well the latest update is that there is nothing wrong with the frame so new bolts, etc on the way from Cervelo to be installed. The paint finish is another story entirely though, but I suppose it justifies paying Hot Tubes to repaint it. A SRAM fd shim has been ordered and that will be installed and hopefully that will solve the issues and bridge the seat tube angle and the fd parameters as told to me by SRAM; so that the tail & front of the fd will align properly at all times..
